Axis length incorrect.
Rob
 Rob
(@rob-26)
Hello, I have a Prusa i3 MK3. After updating the firmware from an old version to the prusa3d_fw_3_14_1_MK3. The axis length is incorrect. If i move the X axis +255 it moves 35mm, Y axis +212 it moves 30mm and z axis 210 it moves 30mm. The Self test gives error: check axis length. If I switch off the printer I can move again other 35mm etc. I've tried installing previous firmware versions, but the error: check axis length, is still there. Auto home gives error too. There are no impediments, moving the axis by hand with the printer off. Does anyone have any idea of the problem.
Opublikowany : 12/08/2025 3:07 pm
