24V PSU cable coupling wiht enclousure secure?
Hello,
I put my Prusa in an own designed enclosure to get higher temps.So the PSU has to go out. Problem is how do I get the 24V power cables and the power panic cable inside?My planned Solution is a printet part that holds EC3 Plugs on the inside of the enclosure like a socket.So I can unplug the printer and get it easy out of the enclosure to work on the workbench an don't have to fiddle around much with cables.The Power Panic cable is not implemented jet because it depends.
Questions:- is it save/ feasible? The EC3-Plugs seem to have the properties to mark the needed properties in Current and Voltage.- I will make new power cables that are long enough to fit to my Assembly. (~1.00m)- for What is the power panic cable exactly? What will happen if it loses the connection? I Will also make a new one for that.
- The general consideratios are that I want to have a save system that don't rise any risks in comparison to the stock Prusa.And i ask her in case I missed something i am not aware of.
The pics show some drafts of my parts.The tweezers represent inside of the enclosure, the knife the PSU on the outside the pens are the wall. its like a side cut.First idea was to have plugs on both sides inside and outside. but then I have two connections that can fail. despite it would be an elegant solution.
RE: 24V PSU cable coupling wiht enclousure secure?
No one?
No Comments.
Dos that mean there is no Risk?
