X offset problem
Julienhirsch
(@julienhirsch)
X offset problem
Hello,
Since some times I have an x problem as you can see on photo.
I print a lot of objects and the problem appears between 7 and 10cms.
The offset is just located on x.
Do you have an idea?
Julien
Posted : 01/06/2021 5:45 am
Julienhirsch
(@julienhirsch)
RE: X offset problem
Posted : 01/06/2021 5:46 am
Check the tension of your X belt.
If that seems OK loosen it and check the x drive pulley has not loosened, this can happen over time if the grub screws are not aligned with the flat first.  Also check the idler pulley - is it crooked? does it move freelly?  Then clean and lubricate the smooth rods before retensioning.  Make your next print:
https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
It MUST be printed in Prusament PETG or the spring tension will be wrong.
What filament are you printing and what is the goop all over the bed?
Posted : 01/06/2021 4:25 pm
Baklin
(@baklin)
Maybe it is a good idea to check over your printer.
Diem has some good points to start with.
But I see one of the screws holding the left z motor is loose. Maybe there are more.
Posted : 02/06/2021 9:35 am
Julienhirsch
(@julienhirsch)
Hello,
Thank you for your help Diem, I will test this solution.
I disassembled all parts and replace z belt motor part. I'm printing belt tensionner.
A+
Posted : 06/06/2021 12:21 pm
