X-axis not well centred?
Ottefant
(@ottefant-2)
Please have a look at the picture i have attached. I am not sure why this happend, but in the prusa slicer I did the position of all these parts inside the white lines. But as you can see the right parts are at the edge of the plate that is well attached. Do I need another calibration here?
Posted : 16/05/2020 8:09 pm
Area51
(@area51)
RE: X-axis not well centred?
X-axis end-stop is detected by hitting the physical left end, making the stepper stall. If something prevents the axis from going all the way to the left, end-stop will be measured wrong.
Try moving the carriage all way to the left, when the printer is powered off - the fan should only be a couple of mm from the z-axis threaded rod.
Posted : 17/05/2020 1:00 am
Ottefant
(@ottefant-2)
Thank you very much, after reading your comment I checked it out and notices that I have printed the old version of that one: https://www.prusaprinters.org/prints/16518
The user made an update just because of that. Never the less it is cool to see that you can print slightly apart from the platform.
Posted : 17/05/2020 12:07 pm
Area51
(@area51)
Happy that you found out 😉
The fan cover looks a lot like the one i designed a couple of years ago: Prusa MK2.5/MK3 Fan Cover, SnapOn
Posted : 17/05/2020 3:31 pm
