Which filament came with my Prusa MK3S?
Mat
 Mat
(@mat-5)
In PrusaSlicer, I'm not sure whether to select Prusament PLA (which is the default one selected when I download the software) or Prusa PLA. I'm using the stuff that came with the printer. The filament box doesn't specify which one it is.
Which setting should I use?
Veröffentlicht : 26/10/2019 5:52 pm
RE: Which filament came with my Prusa MK3S?
I believe the filament that comes with the printer is Plasty Mladec  (PM Filament) the Prusa PLA settings will usually work quite nicely.
Veröffentlicht : 26/10/2019 6:25 pm
BINGOBRICKS
(@bingobricks)
The silver filament that comes with the printer is just "Prusa PLA". Even though, if you compare the two profiles "Prusament PLA" and "Prusa PLA" in slicer, you will find out, that there is no real difference. So, take what you want, the result will be the same.
Veröffentlicht : 12/11/2019 4:54 pm
Jacob Kincheloe
(@jacob-kincheloe)
Mitglied
It’s actually made by Filament PM, not by Prusa
Leave a like if this helped!
Veröffentlicht : 14/11/2019 4:11 am
