What is the purpose of the recess in the latest Extruder Cover STL ?
SteveT
(@stevet)
Rinin Red below.
Steve
Napsal : 23/01/2021 12:45 pm
Matt
 Matt
(@matt-2)
RE: What is the purpose of the recess in the latest Extruder Cover STL ?
It doesn't appear to have any purpose that I can see, other than to reduce material use.
Napsal : 23/01/2021 3:11 pm
1 lidem se líbí
muddymaker
(@muddymaker)
Perhaps it's to aid better airflow to the cooling fins by creating a low pressure spot, therefore aiding the Venturi Effect?
Napsal : 24/01/2021 10:29 am
1 lidem se líbí
Hooch
(@hooch)
It is used to improve cooling by using  the effect of venturi effect.
The air moved by fan inside the shroud goes through smaller diameter opening then fan itself. This increases the air speed and lowers the pressure, thus sucking more air via this side hole.
This is how Dyson "bladeless" fan works. (It has blades but hidden in the base). You can watch a YouTube video explaining how it works to learn something new.
Napsal : 26/01/2021 8:50 am
1 lidem se líbí
SteveT
(@stevet)
So its the fact there is a bump on the inside that is required not particularly that recess I ringed. I guess it could have been flat on the outside and still the lump on the inside of the fan duct.
Okay thanks for the replies that explains my curiosity 🙂
Steve
Napsal : 26/01/2021 11:21 am
