USA Filament that works easily with Mk3 Slic3r profiles
Stránka 2 / 2
CybrSage
(@cybrsage)
Re: USA Filament that works easily with Mk3 Slic3r profiles
I use 3DSolutech as well. Cheap (about $18 a spool), made in the US, and it works perfectly every time. I have used about 8 different colors from them.
Napsal : 20/09/2018 9:56 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
I have had excellent results in my Rostock V2 Delta, which is rather sensitive to dimensional variation, with Sunlu filament via amazon though I expect when PRUSAmelt is sold via the USA amazon I will switch to support What PRUSA is doing to improve the availability of high quality filament.
https://smile.amazon.com/SUNLU/b/ref=w_bl_hsx_s_hi_web_13904457011?ie=UTF8&node=13904457011&field-lbr_brands_browse-bin=SUNLU
it was one of the first major makers of filament to brag of +- 0.02mm Dimensional accuracy which is the standard that PRUSA has settled on as optimal
SUNLU 1.75mm PETG Orange 3D Printer Filament, Dimensional Accuracy +/- 0.02mm, 2.2 LBS (1KG)
Napsal : 23/09/2018 6:42 pm
Stránka 2 / 2
