Under Extruding Issue - Looking for Suggestions to Fix
GT6ixer
(@gt6ixer)
Hello everyone.
Since I finished building my MK3 earlier this year it has been printing without a hiccup until yesterday. After a successful print the day before the next print I attempted failed due to very noticeable under extrusion. I can only get a couple of layers in before the print fails. My MK3 is still stock and I am printing with PLA through a 0.4mm nozzle and using S3D for slicing.
Here are the things I have tried in sequence with each successive print attempt failing due to under extrusion after the change.
*Ran nozzle cleaning filament through a few times
*Re-set tension on the extruder (checked filament/gear/idler alignment)
*Increased flow rate by 5 then 10%
*Did a cold pull
*Changed to a new 0.4mm SS nozzle (didn't have any new brass ones on hand)
*Removed and completely disassembled the E3D hot end. Looked for clogs and there were none. After reassembly I re-ran the setup wizard (adjust PINDA probe, z height etc)
*Tried a different PLA filament (Prusa PLA)
*Updated to latest firmware
*Re-ran z-height calibration (it under extrudes during this as well)
*Tried printing with newest version of S3R Prusa Ed using the stock PLA settings
*Ran PID calibration
So that's what I've tried thus far with no success. Odd thing is if I heat up the nozzle and raise the print head so I can see the filament coming out while manually extruding, it looks fine. It comes out in one smooth continuous strand with no thinning any popping sounds like you get with bad/wet filaments.
So any suggestions anyone may have is greatly appreciated.
Thanks guys!
Nate
Opublikowany : 14/11/2018 6:12 pm
Re: Under Extruding Issue - Looking for Suggestions to Fix
Can't be much help considering you replaced the nozzle with a new one (I presume out of the box new). But I recently had under-extrusion I really couldn't explain and so wanted to blame a FW update. But after many attempts at cleaning the nozzle, the second cold pull fixed it. It was weird, after the first cold pull, which had the V and the 0.4mm orifice clearly defined, it'd print just fine then just stop extruding. I did a couple boils - 285 nozzle temp and extruded PLA, even pulled the nozzle and inspected it, too. Anyway - a second not-so cold pull brought up crap from where I'd expect the nozzle and heat break join is; it looked as if something was between the teflon and heat break that would occasionally jam things. Maybe a piece of debris fell down the outside of the teflon into the heat break when the extruder was busy grinding filament.
I'm wary the problem will come back and I'll need to pull the heater and heat break sometime soon to actually "fix" my printer.
Opublikowany : 15/11/2018 1:18 am
toaf
 toaf
(@toaf)
did you check the calibration on the extruder? roughly mark the filament 100MM from the top of the extruder. run extruder 100. and see how close it is to the top of the extruder. also does the default Gcode work? gotta figure out if its a s3d thing or not.
Opublikowany : 15/11/2018 2:04 am
GT6ixer
(@gt6ixer)
Thanks guys. So I did an extruded test. Never tried that before and I was expecting some discrepancy, however it was 100mm right on the button. So that's good. I don't think the issue is slicer related. As I mentioned above I tried the same part with both S3D and Slic3r with similar results.
Tonight I checked the set screw for the extruder gear and that was nice and tight. Then I set the nozzle to 215°C and and with the idle gear door open I manually pushed PLA filament through the hotend. Not sure what resistance you should feel doing that but it didn't take a lot of force to do it and the filament extruded smoothly. I then raised the nozzle temp to 255° and repeated that process. It was easier to push through witht he hotter nozzle but not significantly. Again it extruded smoothly.
I then performed 3 first layer calibrations. Initially I had a z-height of -0.575 mm set. I chose -0.550, -0.500, and -.450 and looked at the small square test print at the end. All extruded fine with the -0.500 mm height looking the best. I then performed two 20 mm cube test prints from Slic3r. One with speeds set at 45 mm/s and one at 100 mm/s. Both cubes printed fine and without under extrusion. Hmmm that's good. So now I need to try the prints that were failing. I'll report back.
Opublikowany : 15/11/2018 7:31 am
toaf
 toaf
(@toaf)
try throwing something at it with retractions right away. I finally added a clip to my PTFE tube the last time it came loose. also I have a fan on my extruder motor, just because I felt it was getting too hot.
Opublikowany : 15/11/2018 7:48 am
GT6ixer
(@gt6ixer)
^What part of the PFTE came loose and where is there room to add a clip?
I ran a larger print last night. Confounded things by going to a Taulman Alloy 910 because I am almost out of PLA. The 910 was not dry so got lots of pops and therefore layer adhesion was bad. However the print did complete but under extrusion was evident. The model had 4 mm retractions BTW.
I am buying some PLA and will try multiple prints with varying increases in the extrusion multiplier.
Opublikowany : 15/11/2018 5:51 pm
My present concern is whether or not flakes of PLA are inside the teflon tube, or even outside the tube, wedging between the teflon and the stainless heat break; and occasionally were jamming the filament -- and not sliding down with it into the extruder as you'd expect. Especially after blowing out the extruder gears with canned air (lots of debris came flying out - much more than you'd ever expect). So far so good...
I've attached an image of my 1st layer call procedure. Print a large circle, adjust Z so it is filling properly and strands touching; then pull up the layer to check for strand to strand lamination and measure the printed thickness. 0.007 to 0.008 is my goal.
Opublikowany : 15/11/2018 6:12 pm
GT6ixer
(@gt6ixer)
That's a good point. I may take my E3D hot end apart and blow it out and put in a new piece of PFTE.
Your cal piece to me looks a little under extruded. My concern isn't so much the thickness of the layers but the overlap between the strands. Your picture looks similar to my first layers. I can easily pull the strands apart. This normally wasn't case because there was more material being extruded creating a larger overlap.
Opublikowany : 15/11/2018 10:23 pm
toaf
 toaf
(@toaf)
sorry I didn't get back to you sooner, you can add a clip right under the black tab thing on top. if you print one make sure to print a small C clip works like a charm. at least have one laying around for the next time you take the hotend out.
https://www.thingiverse.com/thing:1548181
I don't think that's your issue at this point BUT worth having one ready to pop in.
Opublikowany : 16/11/2018 12:44 am
Peter in Katy
(@peter-in-katy)
Have you tried printing anything off the SD card that came with the printer?
A pre-sliced gcode will price or eliminate hardware.
Opublikowany : 16/11/2018 4:27 am
The flat in my photo is - as far as I can tell - perfect. Right at or perhaps just under 0.200. Strands are firmly joined. The apparent density variation is due to the cheap filament I was using - light on pigment. It looks worse than it is.
fyi: My lower teflon seems wedged into the heat break at the bottom, and contacts the spur gears at the top. I think this is by design because I've never modified my extruder. But the discussion has me wondering if it has crept upward, and that's how crap falling down the tube began jamming.
Opublikowany : 16/11/2018 7:27 pm
bla.n
(@bla-n)
Opublikowany : 17/11/2018 5:56 am
bla.n
(@bla-n)
____________________________________________________
Suspect Link Removed, by Joan.T
Opublikowany : 19/11/2018 11:20 pm
