					                		Strange Noise from i3 Mk3 - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/</link>
                <lastBuildDate>Fri, 12 Jun 2026 07:51:42 +0000</lastBuildDate>
                        <title>RE: Strange Noise from i3 Mk3</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-326905</link>
                        <pubDate>Fri, 18 Dec 2020 14:31:16 +0000</pubDate>
                        <description><![CDATA[To reduce resonance noise from the printer, take a look at this thread Best $7 buck improvement you can make.The heavy base plate will act as a sound low pass filter.]]></description>
                        <content:encoded><![CDATA[<p>To reduce resonance noise from the printer, take a look at this thread <a href="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/best-7-buck-improvement-you-can-make/" target="true">Best $7 buck improvement you can make</a>.</p><p>The heavy base plate will act as a sound low pass filter.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Area51</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-326905</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-326260</link>
                        <pubDate>Thu, 17 Dec 2020 14:13:17 +0000</pubDate>
                        <description><![CDATA[When I moved my MK3S+ to a Lack enclosure, it noise got much louder.  The light-weight Lack enclosure is acting like an speaker cone, transmitting those sounds through a larger surface.  Not...]]></description>
                        <content:encoded><![CDATA[<p>When I moved my MK3S+ to a Lack enclosure, it noise got much louder.  The light-weight Lack enclosure is acting like an speaker cone, transmitting those sounds through a larger surface.  Not that it is all that loud from a decibel perspective, but the tone/pitch is such that it does pass through walls with surprising efficiency.</p><p>I had read of others isolating the printer from the surface it sits on by using concrete pavers and sorbothane pads.  Not having either, I took some of the closed cell foam padding that was around my MK3S+ stepper motors in the Prusa packaging.  I cut some 50 mm x 50 mm squares from this material and placed under each printer foot.  This worked fantastically, I cannot believe how much quieter the printer is -- almost silent.  The loudest sound is now the cooling fans.</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2020/12/IMG_0090.jpeg"><img class="alignnone size-medium wp-image-61954" src="https://forum.prusa3d.com/wp-content/uploads/2020/12/IMG_0090-600x480.jpeg" alt="" width="600" height="480" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>egar</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-326260</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-326173</link>
                        <pubDate>Thu, 17 Dec 2020 10:54:43 +0000</pubDate>
                        <description><![CDATA[Reading further on the web, it seems the above posts are right. The stepper motors move in very small micro-steps, so to move a reasonable distance have to step many times very quickly, in f...]]></description>
                        <content:encoded><![CDATA[<p>Reading further on the web, it seems the above posts are right. The stepper motors move in very small micro-steps, so to move a reasonable distance have to step many times very quickly, in fact so fast that the waveform from the drivers to the motor has a frequency in the audible range. That, along with magnets in the motors, and you've got yourself some small loudspeakers.</p><p>So, bottom line, it's normal and nothing to worry about. I've now had my printer for a couple of years, printed through a dozen or so 1kg PLA spools, and the printer is still printing as good as new!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>mpeill</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-326173</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-326119</link>
                        <pubDate>Thu, 17 Dec 2020 09:13:46 +0000</pubDate>
                        <description><![CDATA[My printer is having the same problem as yours. Have you found the solution yet?]]></description>
                        <content:encoded><![CDATA[<p>My printer is having the same problem as yours. Have you found the solution yet?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>EichmannCharity</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-326119</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-267538</link>
                        <pubDate>Wed, 23 Sep 2020 10:13:36 +0000</pubDate>
                        <description><![CDATA[Come on, check that your device is connected safely?]]></description>
                        <content:encoded><![CDATA[<p>Come on, check that your device is connected safely?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>beverlywalker234</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-267538</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-206145</link>
                        <pubDate>Wed, 08 Apr 2020 16:33:49 +0000</pubDate>
                        <description><![CDATA[There is a Youtube channel that I enjoy where some guy named Paweł Zadrożniak (Polish, I think) has a lot of videos of songs that he covered with his Floppotron musical instrument. Here is h...]]></description>
                        <content:encoded><![CDATA[<p>There is a Youtube channel that I enjoy where some guy named <a href="https://www.youtube.com/user/sh4dowww90/" target="true">Paweł Zadrożniak</a> (Polish, I think) has a lot of videos of songs that he covered with his Floppotron musical instrument. Here is his Floppotron playlist:</p><p><a href="https://www.youtube.com/watch?v=Oym7B7YidKs&amp;list=PLNU8fSoY0vesEhVv1ErMBrhGMr9r464To">https://www.youtube.com/watch?v=Oym7B7YidKs&amp;list=PLNU8fSoY0vesEhVv1ErMBrhGMr9r464To</a></p><p>Enjoy!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Sembazuru</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-206145</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-205246</link>
                        <pubDate>Sun, 05 Apr 2020 17:34:00 +0000</pubDate>
                        <description><![CDATA[I’m glad to hear it, panic over. Thank you.I guess if I print an infinite number of shapes, at some point the motors will play Beethoven’ symphony no. 5😀]]></description>
                        <content:encoded><![CDATA[<p>I’m glad to hear it, panic over. Thank you.</p><p>I guess if I print an infinite number of shapes, at some point the motors will play Beethoven’ symphony no. 5</p><p>😀 </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-205246</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-205239</link>
                        <pubDate>Sun, 05 Apr 2020 17:08:41 +0000</pubDate>
                        <description><![CDATA[They are the stepper motors they can oscillate and make a musical sound , my mk3s does the same. Ive attached a fun link showing that they can produce music]]></description>
                        <content:encoded><![CDATA[<p>They are the stepper motors they can oscillate and make a musical sound , my mk3s does the same. Ive attached a fun link showing that they can produce music.</p><p><a href="https://www.youtube.com/watch?v=YLpf4ZZPJYY">https://www.youtube.com/watch?v=YLpf4ZZPJYY</a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Zachary Lance</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-205239</guid>
                        <title>Strange Noise from i3 Mk3</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-205237</link>
                        <pubDate>Sun, 05 Apr 2020 17:03:43 +0000</pubDate>
                        <description><![CDATA[I&#039;d like to know whether the noise during printing from my i3 is normal or not. Obviously there is the whirring of the stepper motors on x, y, z planes at various stages through the print, b...]]></description>
                        <content:encoded><![CDATA[<p>I'd like to know whether the noise during printing from my i3 is normal or not. Obviously there is the whirring of the stepper motors on x, y, z planes at various stages through the print, but I also get an almost musical sound at some points during the print. I've attached a rather poor recording of the sound, and would just like someone to verify that this is normal, or do I need to be concerned or lubricate something.</p>
<div class="wpforo-attached-file wpfa-deleted">Attachment removed</div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/strange-noise-from-i3-mk3/#post-205237</guid>
