Slic3r Prusa Edition 1.42.0-alpha4
Page 2 / 3
toaf
 toaf
(@toaf)
Re: Slic3r Prusa Edition 1.42.0-alpha4
Loading a multi-part object for MMU is broken. It's already been noted and should be fixed in the next release.
Really? So they broke a fundamental feature as this? What is broken about it, and is there a workaround?
Loading a multi part stl produces something like this. No workaround that I'm aware of. That's the joy of alpha software.
my alpha 4 has not been doing that.
Publié : 02/02/2019 5:12 am
toaf
 toaf
(@toaf)
all I can say is WOW, really if they just add a few more things. slicer is almost a cad 😀
I almost bet they can add a "pen" function and we can draw colors on our stl's.
Publié : 02/02/2019 10:20 am
shaun.m3
(@shaun-m3)
Wish I could find out how to connect the new version to the i3 MK3 using USB cable and Com4 and 11500 setting I used before, damned if I can find how to set this in the new version, or am I to much of a noob............... 😕
Publié : 02/02/2019 9:57 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
if I want to use the usb to the MK3 I use the Pronterface app not Slic3rPR
Publié : 02/02/2019 10:00 pm
shaun.m3
(@shaun-m3)
Agree but slicer is so nice, it is my favourite, after Prusacontrol which is so easy to use, sad I cannot find this option in the new release.......... 😳 😳 😳
Publié : 02/02/2019 10:16 pm
Hi Shaun,
have you disabled the internal raspberry pi port? via the LCD
if not, external usb control, is not available!
Publié : 02/02/2019 10:19 pm
shaun.m3
(@shaun-m3)
Hi Shaun,
I do not use the raspberry pi yet Joan just using Slicer from the laptop........... 😉
Publié : 02/02/2019 10:21 pm
that's the issue Shaun,
it would appear that the default setting for the printer is to connect the control functions to the internal raspi w0 interface, which prevents the external usb port from working with pronterface or Slic3r or other external usb services....
just check the internal raspi port is disabled, and you should be good to go!
Joan
Publié : 02/02/2019 10:27 pm
shaun.m3
(@shaun-m3)
Joan
Cheers for that Joan will look later have a print running from SDcard because Slicer after a crash would not restart the print, but will check that setting at the end of my print, and report back..many thanks.
Publié : 02/02/2019 10:30 pm
shaun.m3
(@shaun-m3)
Hmm RPI is set to disabled already, no difference, I must be missing something so simple................ 😕 😕 😕
Publié : 03/02/2019 12:16 am
Speed 115200?
Does your com port identify itself properly?
Do you
have the driver loaded?
Joan
Publié : 03/02/2019 2:34 pm
Colin
(@colin-4)
This feature has been removed You can no longer print directly to the printer from Slic3r PE. You'll need to use Pronterface, Repetier, SD card, or Octoprint on a RPi.
Publié : 03/02/2019 5:56 pm
shaun.m3
(@shaun-m3)
Speed 115200?
Do you
Joan
Thanks Joan seem to have the answer now, it is not available anymore............... 👿 👿 👿
Publié : 03/02/2019 8:26 pm
shaun.m3
(@shaun-m3)
Thanks Colin, I thought it was me having a me moment, but apparently not, well next project Octoprint with my Raspberry Pi, shall be fun.... 😀 😀 😀
Publié : 03/02/2019 8:28 pm
is that one of the mysterious features removed from Slic3r?
Joan
Publié : 03/02/2019 8:40 pm
toaf
 toaf
(@toaf)
I don't know joan, it still has the print queue.
Publié : 03/02/2019 9:45 pm
Colin
(@colin-4)
That's used for Octoprint.
https://github.com/prusa3d/Slic3r/releases/tag/version_1.42.0-alpha1
Under "Features dropped from this release:"
Online printing over serial line aka the "Controller" was dropped for now. We are not sure yet whether we will integrate it into Slic3r again, or whether we will create a separate application for printer and printer queue control, or whether we will drop the serial line printing for good, as there are other applications that serve the same purpose. Please let us know what you think.
Publié : 03/02/2019 9:56 pm
toaf
 toaf
(@toaf)
I stand corrected.
Publié : 03/02/2019 10:05 pm
Colin
(@colin-4)
I LOVE Octoprint! It's well worth the time to get it set up.
--Colin
Publié : 03/02/2019 10:16 pm
shaun.m3
(@shaun-m3)
--Colin
Certainly will but not putting the Chicken before the egg, still finding my way round, it is good fun............ 😉 😉 😉
Publié : 03/02/2019 11:35 pm
Page 2 / 3
