Slic3r Modifier Problem
stephen.o7
(@stephen-o7)
I'm using V1.41.0 and I am trying to load a modifier that will print a small part of my object with 100% infill. I have modelled the part and the small modifier part and loaded them up to Slic3r. That seems to be fine. I can then add a parameter to the modifier part of 100% infill but...when I slice it the entire part has 100% and not just the modifier section. I tried then to just have the modifier section have more perimeters than the rest but the whole model takes on all the perimeters. I can't even then delete these! If I delete the modifier part the extra parameters are still applied to the whole and I need to delete this too and start from scratch to get back to the normal values.
Does anybody know if what I am trying to do is possible and if I am going about it the wrong way?
Thanks
S
Posted : 22/10/2018 4:20 pm
SamIAm
(@samiam)
Re: Slic3r Modifier Problem
Make sure you are selecting the modifier when you set the infill settings to 100%. That was the solution for me anyway... have to be wide awake to use that form, not very user friendly.
Posted : 02/11/2018 2:22 pm
