rough surface and improper layers build up on the layers build above supports using PVA filament
hi
i am printing using PVA filament but the layers above the supports are so rough and layers are not build on top of each other properly
is there anything i can do to solve that issue
thanks
Opublikowany : 23/02/2021 4:18 am
RE: rough surface and improper layers build up on the layers build above supports using PVA filament
Supports tend to cause roughness to layers above the supports. This is commen.
Opublikowany : 23/02/2021 4:57 pm
