Rattle Noise with Y movement. Is possible to use Rubber pads in bearing like mk4?
Goyetus
(@goyetus)
I see Mk4 is using 1mm rubber pads in the 3 Bed bearings.
It seems to reduce the "rattle noise"  with Y movement......  something that is making me crazy in my 3 mk3s+ units.....
It´s not possible to do this mod in mk3s?     I searched for rubber pad mod or similar,  but cant find anything.
Thanks!!!!
Veröffentlicht : 26/06/2024 7:17 pm
vhubbard
(@vhubbard)
If you could get the pads needed, possibly.  But it may change the Z height of the bed.  Will that cause other problems without the rest of the 3.9 mods?  I don't know.  I tried a Z bracket mod on my mk3s+ and it messed up Z axis homing.
I found on my MK3S+ the Y started to get noisy after 6 months.  It quieted down once I re-torqued all the Y axis rod mounting bolts.  It is part of my 6 month maintenance check now on my MK4 also.  Last 6 month check 2 of the bolts that clamp the Y axis rods were almost a full turn to tight.
Veröffentlicht : 27/06/2024 5:20 pm
Goyetus
(@goyetus)
RE: Rattle Noise with Y movement. Is possible to use Rubber pads in bearing like mk4?
Thanks,  I will try as you say !! 🙂
Veröffentlicht : 29/06/2024 3:04 pm
Allen8355
(@allen8355)
I had this rattle noise on my MK3S+ since it was new. Very frustrating so I changed all the bearings. No difference. But when I moved it to a different table the noise disappeared. So try things related to placement. Different table, on pads, blocks, etc.
Veröffentlicht : 20/07/2024 5:05 am
