PrusaSlicer 2.1.0 - FINAL
Pagina 2 / 2
Mystic
(@mystic)
RE: PrusaSlicer 2.1.0 - FINAL
Could we have an option to print less dense supports at lower layers... e.g. until 10 layers before the support is needed, print it at 1/4 density and 90 degree angle and then use the 10 layers to recover from any bridging problems.
Postato : 21/10/2019 4:09 am
Sembazuru hanno apprezzato
Mystic
(@mystic)
1a. Is it possible to detect filament that isn't sticking and thus a failed print by moving the extruder to the back and then moving it down to 0 (to have the extra filament prevent it from hitting the build plate)?
1b. Is it possible to detect when the printed object is stuck to the nozzle using the procedure described above?
2. If either of the above works, then can we have an option to check every x layers and/or y hours for failed prints?
3. If 1b works, then can we have an option that would verify the object is still stuck by moving the extruder outside the perimeter and seeing if it hits something that shouldn't be there? This would of course be a "every y hours" sort of check.
Postato : 21/10/2019 4:15 am
Mystic
(@mystic)
Last idea (that is for a distant release and one that I could see myself using at some point in the distant future for transparent models that I want no infill in)... Can we have a "create bridging infills in the last x layers" option... that would be used to keep the top layers from bridging, but not have infills throughout the model?
Postato : 21/10/2019 4:23 am
Pagina 2 / 2
