printer suddenly stops for "waiting for temp" then prints out of bounds
Tor
 Tor
(@tor)
see video for the problem.
lots of things happening mid print.
https://photos.app.goo.gl/TtpmB8iesJ1CxS1D8
Posted : 06/07/2019 6:47 pm
RE: printer suddenly stops for "waiting for temp" then prints out of bounds
You have too much friction on one of the axes.  Power off- and move the extruder and bed by hand.  Bed should move front to back without sticking, and extruder should slide left right without sticking or hard sports.
Also, if you have a MK3 (non-S), turn off the filament sensor.
This post was modified 6 years ago by --
Posted : 07/07/2019 1:53 am
Tor
 Tor
(@tor)
Why do you think I have too much friction? This has happened twice now on almost the same place. (same model).
And why should I turn off the filament sensor? it's worked as it should for almost a year now.
yesterday I printed 4 other models for 10 hours straight. no issues. yes, that same white filament.
Posted : 08/07/2019 8:50 am
vintagepc
(@vintagepc)
You're not the only one with this issue, it's definitely not friction.
https://github.com/prusa3d/Prusa-Firmware/issues/1522
It's the filament sensor registering a false jam or runout. Check your fail stats after it happens to see if the runout count has incremented. For some reason it will occasionally lose the planning buffer and run off the print area or cause a layer shift.
Posted : 08/07/2019 11:08 am
