Printer started to print offset to plate
fhowland
(@fhowland)
I recently started having an issue where the printer is offsetting the print from the slicer (so much that the print goes off the plate). It's also counting up (not down) like it use to for remaining print time and is no longer doing a filament purge before printing.
Posted : 13/03/2020 9:30 pm
kpreid
(@kpreid)
RE: Printer started to print offset to plate
Purging is programmed in the G-code, not the printer firmware. That and the other problems suggest that you are generating G-code for the wrong printer model, or perhaps you cleared or damaged the "Start G-code" from your printer settings if you are using PrusaSlicer.
In PrusaSlicer, confirm that the "printer" profile is set to "Original Prusa i3 MK3" (or …MK3S or …MMU2 depending on which variant you have) and not a "(modified)" copy of that profile.
Posted : 13/03/2020 10:14 pm
fhowland
(@fhowland)
@kpreid
That was it........Thanks for the quick response kpreid.
Posted : 14/03/2020 3:38 am
