[Rozwiązany] Pretty PLA V4.
terry.a2
(@terry-a2)
Pretty PLA V4.
So i have been having an interesting problem with Prusaslicer and the Pretty PLA v4 profile.   Since i got my adhesion issues fixed (Thank you Bobstro for the cleaning tips on your site.)   i thought i would try out the Pretty PLA profiles.     I download the v4.0 from prusa's site and import it into prusaslicer.  everything looks good and i am able to work with it.
My issue starts when i reopen Prusaslicer  after importing I see the SL1 bed on the screen and the SL1 is selected as my printer which i don't own an SL1.  I switch it back to the mk3 and the pretty profile is completely gone from the list and i have to re import to get it back which only goes through the same problem.
Anyone else have this issue.  I am using Prusaslicer 2.1
Opublikowany : 18/03/2020 6:57 am
terry.a2
(@terry-a2)
RE: Pretty PLA V4.
An update to this.  I did stop Prusaslicer from resetting to the SL1 on start. i went throught the install wizard and unchecked all printer but the mk3.  Now everytime i install the pretty pla profile and close prusaslicer when i reopen the pretty profile is completely gone..
Opublikowany : 21/03/2020 6:08 am
Area51
(@area51)
RE: Pretty PLA V4.
Just a suggestion. Try installing the Pretty PLA profile and select the gear to the right of the filament drop down and re-select it in dialog. This will maybe auto select it again the next time you open PS.
Opublikowany : 22/03/2020 1:49 am
terry.a2
(@terry-a2)
RE: Pretty PLA V4.
Posted by: @area51
While the suggestion unfortunately did not work it did put me on the right track.    Saved a copy of the profile in PS and removed the original. Closed down several times and it was there on reopen.  Thank you @area51.
Opublikowany : 22/03/2020 9:18 pm
