Original Prusa i3 MK3S vs MK3 + important links
Page 3 / 3
Patrick.b
(@patrick-b)
RE: Original Prusa i3 MK3S vs MK3 + important links
Jakub thanks for this all links it's useful .
But would it be possible to get better printed part in the kit...and maybe modify the Adapter-printer (1x) FS-lever (1x) or at least have a very nice printing part for the FS-lever . i build up my 3rd MK3s and really the 1st was really good but recently the printed part must be modify by hand oftently . I've got huge issue with the sensor only because the filament couln't come out because he couldn't find the hole after pass the small ball . As the sensor is very sensible and that good , but then the little corner which give 1 or 0 let the filament goes too far if be ex you cut the filament to try the function change filament ...while your spool is empty ..hope you foloow me.......... 😥 ..those part are really extremely sensible and have to correct and unscrew 3 times the extruder ,
thanks
Publié : 08/02/2020 10:06 am
Sean Bancroft
(@sean-bancroft)
Wow, it`s cooL!
Publié : 16/03/2020 6:21 pm
Chris
(@chris-16)
@jakub, how soon will the mk3s+ parts be up for download?
I need to rebuild my x and y axis (new bearings) and have the bearing caps and the super pinda on the way, just need to print the parts so i can update.
Publié : 30/11/2020 8:59 pm
1 personnes ont aimé
James AZ
(@james-az)
Having just completed the MK3S to MK3s+, I offer the following:
Inspect your newly MK3S+ printed parts CAREFULLY.   I had a minor layer shift occur while printing them that I did not notice at first.  After completely disassembling my original MK3S per the instructions, I found the layer shift.  The new parts were not useable.  My printer was disassembled, I couldn't reprint the new parts.  I either had to reassemble and recalibrate my MK3S or find a way to get the new parts.  Using the "World" section above, I was able to locate a user near me who graciously printed the new parts at no cost.
A special thank you to "JWG" in Queen Creek, AZ, USA
Publié : 23/01/2021 4:32 pm
Asraff Amzani
(@asraff-amzani)
I have quick questions for the new parts. I am not sure which part I'm using now probably R4
  1. Would R6 parts compatible with the MK3S hardwares especially the IR and Pinda?
  2. Would R6 fits into R4 or R5 parts?
  3. What other improvement introduced in the new R6?
Publié : 14/05/2021 2:04 pm
BpiccuK2
(@bpiccuk2)
RE: Original Prusa i3 MK3S vs MK3 + важные ссылки
Posted by: @olef
Your firmware link does not work Peter... try this one https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.1.1
Slic3r link also - https://github.com/prusa3d/Slic3r/releases/tag/version_1.39.1-alpha  time tracking software
Thank you!
Jim Rohn "Discipline is the bridge between goals and accomplishment."
Publié : 18/06/2021 3:22 pm
dinner line
(@dinner-line)
On the off chance that you think, something is missing, if it's not too much trouble, let me know beneath and as consistently Cheerful Printing!
Publié : 13/02/2023 6:00 am
Mohsen Khanbeigi
(@mohsen-khanbeigi)
RE: iniital installation crash, unhandled unknown exception, terminating the application!!
A strange crash is taking place after the installation of software (in all version and all modes) on my new Win11 laptop, i had pursa on my old system(Win 8) w/o any problem but i cant even run the software on this, installation done somoothly but right after i run it a popup appears : "unhandled unknown exception , terminating the application" i push OK , the software closes immidiately, tried again and again and studied the community discussion, i could not find an answer!
Will appriciate your advices.
Thanks
Mohsen
Publié : 28/02/2023 5:22 am
Chris
(@chris-16)
Posted by: @mohsen-khanbeigi
Thanks
Mohsen
Check windows event log and copy the whole error and add it to your post
Publié : 28/02/2023 6:09 am
NickAtNight
(@nickatnight)
Download for Mac Pronterface does not work in MacBook Pro (wrong but level)
Publié : 05/03/2023 2:02 am
JUAN M
(@juan-m)
Membre
BUENOS DIAS ME LLAMO JUAN ESPERO QUE ME DISCULPEIS POR ESCRIBIR EN MAYUSCULAS PUES SOY DIACAPACITADO Y TENGO PROBLEMAS DE VISION TENGO UNA MINUSVALIA DE UN 80% GRACIAS
HACE UN AÑO Y MEDIO QUE COMPRE LA IMPRESORA SIEMPRE ME HA FUNCIONADO BIEN, ASTA HACE DOS DIAS PUES ME DA UN PROBLEMA CUANDO LA CALIBRO EN EL EJE Y Y ADEMAS UN ERROR. OS ADJUNTO UNA CAPTURA Y POR FABOR HABER SI ALGUIEN ME PUEDE AYUDAR PUES ME DA ESTE ERROR Y UN PITIDO Y NO SE LO QUE ES. GRACIAS.
Publié : 24/08/2023 2:48 am
La pantalla muestra un error en la temperatura de la base calefactora. la temperatura 0 centígrados no coincide con la temperatura de la boquilla.
esto sugiere que el cableado del termistor está en circuito abierto.Mintemp ocurre cuando la temperatura es inferior a aproximadamente 15 ° C o cuando el circuito del termistor tiene una resistencia muy alta.
En uso normal, una impresora 3D (Bed Slinger) mueve la base térmica hacia adelante y hacia atrás repetidamente, lo que hace que los cables se flexionen repetidamente.
La flexión repetida tiende a causar fatiga del metal en los cables.Después de mucho uso (o si el montaje es incorrecto) es probable que el cableado se rompa. lo que lleva a una alta resistencia y posterior falla.Lo más probable es que el cable haya fallado cerca de la abrazadera del cable en la base calefactora o cerca de la abrazadera del cable en la caja Einsy/rambo.Puede reemplazar el cable que comienza debajo de la base calefactora y termina dentro del Einsy/Rambo para reemplazar ambas secciones donde es probable que se produzcan fracturas.Los cables no son conscientes de la polaridad.
Buena suerte,joan
the display shows an error on the heatbed temperature. the temperature 0Centigrade does not match the nozzle temperature.
this suggests that the thermistor wiring is open circuit. Mintemp occurs either when the temperature is below about 15C or when the thermistor circuit is very high resistance
In normal use, a 3D (Bed Slinger) printer, moves the heatbed backwards and forwards repeatedly which causes the wires to flex, repeatedly.
Repeated flexing tends to cause metal fatigue in the wiresAfter a lot of use, (Or if the assembly is incorrect) it is likely that the wiring will fracture. leading to a high resistance, and subsequent failure. It is most likely that the wire will have failed near the cable clamp in the heatbed, or near the cable clamp on the Einsy/rambo case. you could replace the wire starting under the heatbed and ending inside the Einsy/Rambo in order to replace both sections where the fractures are likely to occur. the wires are not polarity conscious.
Good luck, Joan
Publié : 21/02/2024 10:29 am
burtronix
(@burtronix)
I'm having trouble finding MK3S firmware 3.13.2. It has been released since Oct 2023, but the Prusa Downloads page shows 3.13.1 as the latest release ( Sept 2023). I went to GitHub & found the source code for 3.13.2, but I can't seem to find the HEX file for doing the flash upgrade. (I don't know my way around GitHub very well).
So, question #1: why isn't 3.13.2 on the Prusa Downloads page?
Question #2: how do I get HEX files from GitHub?
Whatever you find to do with your hands, do with all your might!
Publié : 27/02/2024 8:55 pm
ga
 ga
(@ga)
The MK3S has a printable area of 250 x 210 x 210, but the MK3S+ and MK4S have printable areas of 250 x 210 x 220.  Yet the upgrade kits say nothing about a larger bed, wider frame, or anything else that would result in a larger print area.  How is the larger print area achieved?  Is that due to changes in the extruder?
Publié : 05/05/2025 3:17 am
Chris
(@chris-16)
Posted by: @ga
The mk3s is still 210 in z, in the mk4 they move the extruder up 10 mm
Publié : 05/05/2025 3:33 am
ga
 ga
(@ga)
Thanks, my mistake.
Publié : 05/05/2025 8:53 pm
Page 3 / 3
