How do I enable Linear Advance?
dimprov
(@dimprov)
I want to enable Linear Advance. Am I required to do that at the g-code level, or is there some other setting (maybe "E-Correct"?) which does it?
Anything else I need to do?
I'm running firmware 3.2.1.
Posted : 08/06/2018 9:38 pm
Nikolai
(@nikolai)
Re: How do I enable Linear Advance?
M900 K0 = LA off
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Posted : 08/06/2018 10:29 pm
ron-f
(@ron-f)
If you use slic3rpe, you will see in filament profile, m900 gcode commande with a specific value. K is different for each material. By sending a K value, you set up linear advance. As said K0 disable the linear advance. If you don't send a m900, the firmware uses K0.
You can even calibrate linear advance for your filaments: https://mattshub.com/2017/10/02/linear-advance/
Posted : 08/06/2018 11:11 pm
RobertB67
(@robertb67)
I found this video from TT big help setting up Linear Advance.
Posted : 13/06/2018 9:52 pm
