Here's a good scraper
FWIW, I've found this plastic scraper to be really helpful in removing stuck bits of filament from the heat bed:
http://a.co/dNyAMjj
Prior to that I was using my thumbnail, but this scraper works better.
Re: Here's a good scraper
im so scared of putting a razor blade anywhere near my pei flex sheet, especially when we cant even get replacement sheets at this point. i havent had the need to use anything other than flexing the sheet.
Well, these are plastic razor blades. That's the whole point.
Granted, in your case it sounds like you don't need it.
I may have to get some of those blades. I’d probably print a handle tho...
When someone asks you if you're a god, you say, "YES!"
Best 3d printed razor scraper handle ever...Not sure the plastic razors will fit.
https://www.thingiverse.com/thing:1998301
I think I've printed a dozen of these for family and friends, always get positive feedback once they get a chance to use it. Fits the hand just great.
It fits. I guess. As you can see, my print came out smooth, but it has these annoying rough edges near the blade. How should I best smooth/remove them? I printed it using Monoprice's PLA Plus, which supposedly is stronger than regular, plain vanilla PLA.
Hmmm.. I wonder if these plastic blades could be 3D printed? I don't see why not. If so, what wold be the best material to print them with? Maybe the same PLA Plus?
That might be an extrusion or retract issue.
Try these two quick tests on your printer.
https://www.thingiverse.com/thing:2753088
https://www.thingiverse.com/thing:1622868
I've used Inland PLA on all my scraper handles w/o an issue on both my Mk2s and Mk3. I normally print these at .15mm layers w/25% grid infill. I did try PETG (orange handle in pic, blue is PLA), but found it was just a bit too flexible in the blade area. The blade recess slots are very tight...designed that way I think to make sure the blade does not move.
