Help!! There is some kind of wire sticking out about 5 inches from the where you load filament into extruder.
[Résolu] Help!! There is some kind of wire sticking out about 5 inches from the where you load filament into extruder.
rmenousek
(@rmenousek)
This is on my brand new machine on setup. I tried pulling it out, but not successful.  Anyone received the same thing on assembled i3 MK3S+ and know how to remove it?
Publié : 04/07/2022 3:53 pm
RE: Help!! There is some kind of wire sticking out about 5 inches from the where you load filament into extruder.
Picture?
Publié : 04/07/2022 3:58 pm
Membre
There should not be a wire where you are describing.  I agree a photo is needed.
Posted by: @rmenousek
Publié : 04/07/2022 4:14 pm
rmenousek
(@rmenousek)
Duh.  It was the filament.  When I went through the setup it heated it up and said to remove.  Guess I did not go far enough.  Thank you for the quick response.  BTY, silver/gray filament, so it looked like a wire.  Buddy is printing now!!
Publié : 04/07/2022 4:23 pm
Just to exclude the trivial — it's really a wire, not some filament?
Publié : 04/07/2022 4:35 pm
rmenousek
(@rmenousek)
See my last post.  Yes it was filament.
Publié : 04/07/2022 4:39 pm
Membre
Well, that should be easy to rem0ve.
Publié : 04/07/2022 4:49 pm
I didn't see any other post than the one in which you mentioned the wire. So I guess you're all set now?
Publié : 04/07/2022 4:57 pm
rmenousek
(@rmenousek)
Yes, once heated up said remove filament.  Came right out.  This forum rocks.
Publié : 04/07/2022 5:05 pm
Somtimes we miss the blindingly obvious...
I have tried to print PETG at PLA temperatures... didn't go well!
took me a while to work out that I have picked the wrong roll of filament up!
Publié : 04/07/2022 5:11 pm
