Getting Random "Elephants Feet" on my prints
jweaver
(@jweaver)
I have had flawless printing on my MK3 since day one, but recently I have noticed that some prints come out with a sharp ridge (Elephants foot) around the first layer
I do a regular job where I print 24, 38, 56 or 88 of the same items on the bed, and some of these exhibit the issue, and I am trying to work out whether its a particular area of the bed thats affected.
Anyway, yesterday I printed a 100x70x10mm block that I have printed many times before, right in the middle of the bed and it was perfect.
But today, I printed the same job using the same gcode and the same filament and I have a 0.5 ridge at the base where the first layer is bigger than the rest.
How can this be? Nothing has changed? I am using the same filament, the same settings and the same gcode?
Can anyone explain this and perhaps offer a solution?
Posted : 13/10/2019 4:51 pm
jweaver
(@jweaver)
RE: Getting Random "Elephants Feet" on my prints
Here is a pic of yesterdays print:
Posted : 13/10/2019 4:53 pm
jweaver
(@jweaver)
And todays
Posted : 13/10/2019 4:54 pm
Steve
(@steve-3)
My two guesses are a change in temperature or a worn out nozzle.
Steve
Posted : 13/10/2019 5:14 pm
jweaver
(@jweaver)
Posted by: @steven-p8
Steve
Cheers Steve... Temperature no... Printed the same time of day and the central heating is on... So the house is at a constant temperature.
Worn nozzle is a VERY likely explanation.. I am still on my 1st Nozzle and have printed 10,000s of Meters.. But how could it change so much in 24 hours.. Literally.. I have the prints side by side and they are totally different...
Posted : 13/10/2019 5:21 pm
Random temp changes during mesh leveling will cause this if the gcode doesn't wait for the PINDA to stabilize to a known temp.
Make sure you use M860 in the start-up gcode and random temp variations can be minimized.
Posted : 13/10/2019 9:05 pm
jweaver
(@jweaver)
Posted by: @tim-m30
Odd that I created the gcode files for these prints years ago and have not had any problem before now.. But I will look at the M860 option to see if it helps.
How best to use it.. Bring the prinda close to the bed and let it warm? What temperature should I use with the M860 command?
Posted : 14/10/2019 12:47 pm
Sembazuru
(@sembazuru)
There are several examples of PINDA heatup routines. The only one that I remember off the top of my head is by @bobstro and published with explanations here:
http://projects.ttlexceeded.com/3dprinting_prusaslicer_gcode.html
See my (limited) designs on:
Posted : 14/10/2019 5:04 pm
jweaver
(@jweaver)
@sembazuru
Cheers.. I got that one and only last week added it to a new printer profile.. I have been using it but the longer start up times annoyed me, so reserved it for when I have the time.
The problem I have here is that I created the g-code that I am using over 2 years ago and its been faultless, and now, using the same filament and settings I am having problems.
I sourced a new nozzle today, so I am going to swap that before going too deep.
Posted : 14/10/2019 5:22 pm
jweaver
(@jweaver)
My problem has got even worse and I was finding that I could not even lay down my first layer.. During my drive home, i had a sudden brainwave and had a thought as to what the issue was.. And I was right
I had toggled from my Smooth bed (z = -0.375) to my Textured bed (z=-0.650)... So my Z was 0.3mm too low...
I do love the new feature where you can change beds.. But i wish it gave you some kind of warning.
I am just glad its solved as I have been unable to print properly for a few days now.
Thanks for everyones help
Jon
Posted : 15/10/2019 5:32 pm
Sembazuru
(@sembazuru)
Posted by: @jweaver
Jon
Ok... new mod idea:
RFID tags on each side of the bed (each side might have a slightly different coating thickness, particularily DIY beds that might have completely different print surfaces) and an RFID reader on the Y carriage. When starting the mesh leveling routine (and/or manually from the menu when not printing) the FW reads the RFID and chooses the right stored z-height based on the serial number in the tag. Could probably use the small glass encapsulated RFID tags used to chip pets, and encase them in a small mound of epoxy under the front-left corner of each side of the flexible bed. That way the epoxy bump is on the front corner away from where the purge line is done.
Posted : 15/10/2019 6:32 pm
