Firmware 3.9.0-RC1 for Original Prusa i3 MK3S & MK3
Strona 1 / 3
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Hi guys,
this a release candidate of the upcoming firmware version 3.9.0. This version was thoroughly tested and is dedicated to a broader audience, but keep in mind it is still a testing version!
Summary:
  • Power panic fixed
  • Automatic E-jerk conversion
  • Heating disabled during MBL
  • MINTEMP value lowered
  • MINTEMP error differentiated
  • Filament sensor sensitivity fix (MK3)
  • Flickering “Statistics” screen fixed
  • Tone timer re-enabled
  • “Unknown height” displayed for Z-axis fixed
This is a release candidate of the upcoming firmware 3.9.0 with several fixes for bugs discovered in the previous beta release.
Detailed description
Power panic fixed
The power panic function didn't work properly in the previous beta release. This issue is now fixed. Also, during the debugging, the developers discovered a way to further optimize the code. This release corrects an issue with data being reset on “Fail stats > Last print” and also fixes a scenario in which the printer would fail to heat up the hotend during the recovery. This caused an issue when the printed object could detach from the sheet as the extruder moved.
With the introduction of Linear Advance 1.5 to the firmware, it was also necessary to convert the values of the E-jerk, originally used for Linear Advance 1.0. Based on internal testing, it was decided to set the conversion of the E-jerk parameter from 1.5 to 4.5. If there is a different E-jerk value in the G-code file, the printer uses the function shown in the graph below to convert the value correctly.
LA15vs10_ejerk
The Pulse-width modulation (PWM) of the heated bed created an electromagnetic field, which had a negative impact on the P.I.N.D.A. sensor during the mesh bed levelling (MBL) procedure. To increase the reliability of the measurements, heating is temporarily disabled above each measured point during the MBL.
Based on the feedback from the community, the minimal operational temperature was lowered from 15°C to 10°C (59°F to 50°F).
Previously the firmware displayed a message “MINTEMP FIXED” after a successful recovery in an environment with low temperature. New firmware distinguishes between “MINTEMP HOTEND FIXED” and “MINTEMP BED FIXED”.
The new Linear Advance 1.5 function was causing issues on older MK3 printers equipped with the IR filament sensor. The sensitivity of the sensor was adjusted to prevent false filament runout detections. Most problematic colours were pink and transparent green filament.
The screen displaying the statistics was flickering during the print due to an error in the code responsible for refreshing the screen. The error is now fixed.
The function responsible for the tone playback was broken in the previous release. It is now fixed and available at timer4 (timer2 is used as a system_timer) both for Einsy (MK3S) and MiniRambo (MK2.5S).
There were several reports that the printer would display “?” instead of the Z coordinate. This happens, when the printer isn't sure about the exact position (height) of the Z-axis. The issue was caused by the behaviour of the black Delta PSU. This is now fixed.
Supported printers:
  • Original Prusa i3 MK3S MMU2S
  • Original Prusa i3 MK2.5S MMU2S
Download link:
https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.9.0-RC1
Note that MK3S, MK3, MK2.5S and MK2.5 are different printers! Each has its own firmware file!!!
Firmware flashing guide:
https://manual.prusa3d.com/Guide/Upgrading+the+firmware/66
Please report any bug here:
https://github.com/prusa3d/Prusa-Firmware/issues
As always, we wish you happy printing and look forward to your feedback!
This topic was modified 6 years temu 2 times by Jakub Dolezal
Assembly manuals
/ Knowledge Base
Opublikowany : 17/02/2020 11:01 pm
1 ludzie polubili
Wes
 Wes
(@wes-4)
RE: Firmware 3.9.0-RC1 for Original Prusa i3 MK3S & MK3
Is there a link yet to the new selector parts needed for the new MMU2S string cutting feature?
Opublikowany : 18/02/2020 2:58 am
towlerg
(@towlerg)
"Based on the feedback from the community, the minimal operational temperature was lowered from 15°C to 10°C" I hope they do that for the Mini as well.
Opublikowany : 18/02/2020 1:09 pm
vintagepc
(@vintagepc)
Posted by: @wpegden
No. Still being tested internally.
Opublikowany : 18/02/2020 2:01 pm
Protoncek
(@protoncek)
This firmware supposely adds brightness control to MK3S's LCD. Since many of us have printer, made before late 2019 i wonder, is there a schematic available to convert old LCD ? Since it uses same two flat cables it shouldn't be too dificult to modify old LCD, right?
Opublikowany : 19/02/2020 12:08 pm
morf
 morf
(@morf)
Hi Folks,
I'm the mk3s user, with the introduction of LA 1.5 according to Marlin docs ( https://marlinfw.org/docs/features/lin_advance.html ) previous (v.1.0) K-factor is no longer valid, and a change should be applied.
New K value required
As the unit of K has changed, you have to redo the K calibration procedure. See next chapter for details. While old v1 K values for PLA might be between 30-130, you can now expect K to be around 0.1-2.0.
Just a question: Shouldn't PrusaSlicer profiles should be now updated with calibrated with the new LA 1.5 factor?
or is it hardcoded in firmware?
This post was modified 6 years temu by morf
Opublikowany : 19/02/2020 12:27 pm
vintagepc
(@vintagepc)
Posted by: @visual
Hi Folks,
Not required, the values don't overlap and they (Prusa, not Marlin) implemented it so that old 1.0 factors are interpolated to new 1.5 factors. No immediate action is required, but longer term I'm sure it will be updated.
Posted by: @protoncek
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles-.../old-lcd-board-modification-to-allow-fw-3-9-0-brightness-control/
Opublikowany : 19/02/2020 2:14 pm
Protoncek
(@protoncek)
@vintagepc: Many thanks!
Opublikowany : 19/02/2020 3:22 pm
1 ludzie polubili
Bennji
(@bennji)
RE: Firmware 3.9.0-RC1 für Original Prusa i3 MK3S & MK3
@vintagepc
New Parts online (github)
Opublikowany : 03/03/2020 3:28 pm
1 ludzie polubili
vintagepc
(@vintagepc)
Posted by: @bennji
@vintagepc
Now just to wait for someone to remix it into the "opened canal + ball magnet" design XD
... Or I may do that myself if the author shared the original part SCAD.
Opublikowany : 03/03/2020 4:07 pm
Lichtjaeger
(@lichtjaeger)
Posted by: @vintagepc
They are all on Github. It's the mmu2-selector-finda.scad file.
Opublikowany : 03/03/2020 5:04 pm
vintagepc
(@vintagepc)
Posted by: @lichtjaeger
I'm aware of that, I was referring to the SCAD file for the thingiverse remix with the changes I mentioned, so I could combine the two.
Opublikowany : 03/03/2020 5:44 pm
Texy
 Texy
(@texy)
Posted by: @jakub-d
Hi guys,
Summary:
  • Power panic fixed
Power panic fixed
LA15vs10_ejerk
Supported printers:
Download link:
The title implies RC release, but the link now goes to the Beta ???
This gets to the RC release :
Texy
This post was modified 6 years temu by Texy
Opublikowany : 06/03/2020 5:35 pm
Texy
 Texy
(@texy)
Yes I know they look the same, but for me they go to two different urls
Texy
Opublikowany : 06/03/2020 5:42 pm
Sembazuru
(@sembazuru)
Posted by: @texy
Texy
This is likely why:
It seems that the url text was changed, but the actual url link wasn't. Probably a copy-paste error.
See my (limited) designs on:
Opublikowany : 06/03/2020 6:42 pm
RadimR
(@radimr)
It's been almost three weeks since the RC, with no final release and no new RC.  Is there a major silent issue with this RC or is there another reason for still holding this back?
Opublikowany : 07/03/2020 6:15 am
vintagepc
(@vintagepc)
Posted by: @radim-r
There are still a handful of remaining tweaks to be merged, I'd imagine they are testing those right now and we'll see something before long.
Opublikowany : 07/03/2020 11:35 am
Texy
 Texy
(@texy)
I have an issue with this release - the extruder doesn't extrude when I print from SD card. If I print the same gcode from Octoprint, it prints fine.
Any idea's ? I'll be uploading a video shortly.
Texy
Opublikowany : 10/03/2020 7:10 pm
Texy
 Texy
(@texy)
IMG_6753
As you can (hopefully) see - the extruder just moves one way, then the next.
Opublikowany : 10/03/2020 8:34 pm
vintagepc
(@vintagepc)
Posted by: @texy
IMG_6753
https://github.com/prusa3d/Prusa-Firmware/issues/2516
Your extruder is in absolute mode due to a change copied from Marlin 2.0 that has since been reverted. It'll be back to normal in the next RC or final release, I believe.
Summary: Marlin 2.0 changed G90/91 to also affect the extruder. Many sliced codes for older variants assume those codes don't alter E relativity and therefore don't issue the appropriate M command to keep or swap E back to relative mode.
Opublikowany : 10/03/2020 8:59 pm
Strona 1 / 3
