Filament sensor actually works?.....NOPE
Page 2 / 2
rob.l6
(@rob-l6)
Re: Filament sensor actually works?.....NOPE
Wow, so I am the bad guy for expecting a machine to work as advertised....
So Rob and Nikolai, when you buy a product you don't expect it to work as advertised?
Nobody said you are the bad guy, just being a little unrealistic.
In this world of complex machines, anything more sophisticated than a dishwasher will probably get firmware updates to fix issues. That is the reality. Then again our dishwasher got a firmware update recently, so it can even happen to them.
However, if you can't see the value in a Prusa then you should definitely get rid of it. It isn't worth getting upset over.
Posted : 06/05/2018 8:17 am
Joe Prints
(@joe-prints)
I do not understand how this is unrealistic.
Straight from prusaprinters.org:
Our optical filament encoder not only detects the presence of a filament, but also its movement. This means we can detect running out of the filament, pause the print and ask the user to insert a new spool. That is pretty basic. But we can also detect stuck filament and offer the user a cold pull to clean the nozzle and continue the print.
The Extruder motor can detect a jammed extruder
Advertised that it works fine, but not enabled in FW? Even crappy companies like DaVinci make sure the whole machine works.
According to Czech law, you could get a discount if a product is not as advertised. Might be worth asking Prusa
Thanks tomp, I will be looking into that
Anything can be made better
https://www.myminifactory.com/users/Joe%20Prints
Posted : 06/05/2018 1:52 pm
rob.l6
(@rob-l6)
Clearly.
Posted : 07/05/2018 4:12 am
Page 2 / 2
