Extruder assembly started smelling like burning plastic after 12-days of no issues
Mike S
(@mike-s)
I have an issue with a burning plastic smell that just started on a fairly new Mk3sS that I am almost certain is coming from the extruder assembly but I can't find the cause. I have been printing mostly PETG (Polymaker White and Prusament Orange).
It happens if I heat the extruder and not the bed and the odor is definitely worse right at the extruder. It's enough of an odor I can smell it in the entire house within 10 minutes of printing.
This is ~1 month old Mk3S with approximately 320 hours of printing and it has been working near flawlessly since I built it. Even with the odor the printing is perfectly fine - no issues at all.
The burning plastic issue has been happening for about the past 12-hours of printing.  I've cleaned the heater block and nozzle (wire brush while hot) and made-sure the nozzle is tight (also while hot). Everything looks fine - nothing seems to be overheating and there is no smoke or other visible issue.
Any insight? It's such a bad odor I can't print with anyone else at home.
Thanks
Mike
Posted : 06/01/2021 7:05 pm
RE: Extruder assembly started smelling like burning plastic after 12-days of no issues
Posted by: @mike-s-2
Thanks
Mike
Have you checked all 24V contacts (also the Einsy contacts) for corrosion, bad connection or melted cable insulation?
Posted : 06/01/2021 10:20 pm
Mike S
(@mike-s)
@karl-herbert
Yes - I checked everything. It's a fairly new build. I can definitely smell the odor on the side of the extruder as the cooling fan turns-on. I don't get any smell until I start heating the nozzle.
I'm also using one of those laser-spot-thermometers to double-check the heat everywhere and nothing looks terribly hot anywhere it's not supposed to be.
I'm stumped - even if there was some residue I would have thought it would have burned-off by now. I hate the thought of taking apart the extruder assembly as I don't even know what I would look for - there's no visible signs of any stuck plastic or leaking.
Thanks for the suggestions.
Posted : 06/01/2021 10:35 pm
Matto
(@matto)
Is there a leak above the heater block?  They are sometimes very hard to spot, and a slow leak would just burn off plastic on the top of the block.  (Not that I am speaking from experience here.... 🙂  )
Stock Prusa MK3S+ built from kit on 12/2020
OctoPrint, typically print from a drybox, no enclosure yet
Printing proudly since 2011
Posted : 07/01/2021 3:41 pm
Mike S
(@mike-s)
@matto
That's a very good question - I see nothing at all but I definitely smell it. I am guessing I'm stuck with disassembly of the hot-end assembly to even check for a leak.
How did you spot the issue in your case?
Thanks for the feedback.
Mike
Posted : 07/01/2021 7:01 pm
