Cura settings for the Original Prusa i3 printers
Seite 1 / 5
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Good News Everyone!
Josef and his team created a bundle of settings for the Cura software! After rigorous testing, we are happy to add support for Original Prusa i3 printers. Use our step-by-step guide to import the settings 😉
Link to the guide (includes the package with settings):
https://help.prusa3d.com/en/guide/how-to-import-profiles-to-cura-4-x-windows-macos_17848
Direct link to the settings:
Original Prusa printers
Supported printers:
Original Prusa MINI
Original Prusa i3 MK3S
Original Prusa i3 MK2.5S
Original Prusa i3 MK2/S
Supported materials:
Prusament PLA
Prusament PETG
Prusa PLA
Prusa PETG
Prusa ABS
Supported OS:
Microsoft Windows
Apple macOS
Changelog:
07/2020
Version 1.5
- Support for Original Prusa MINI
04/2019
Version 1.4
- All files tested to comply with the Cura 4.0.0
- This version isn't compatible with the 3.x.x releases
- New settings improving the printing quality
- New material profiles for Prusament
10/2018
- Version 1.3
- All files tested to comply with the Cura 3.5.1
- Added files to folders Cura_printer_extruders with additional settings
- Correction for MK3 retraction 0.2 Fast
06/2018
- Version 1.2
- Original Prusa i3 MK3 all layer height profiles updated - retraction/infill/supports
- Original Prusa i3 MK2.5 all layer height profiles updated - retraction/infill/supports
- Original Prusa i3 MK2S all layer height profiles updated - retraction/infill/supports
- Note: Delete your old layer height profiles and import new ones.
06/2018
- Version 1.1
- Added support for Apple macOS
05/2018
- Version 1.0 [initial release]
- Support for Original Prusa i3 MK3 / MK2.5 / MK2S
- Support for Prusa ABS / PETG / PLA
- Support for Microsoft Windows
- Tested on Cura 3.3.1 x64
Happy printing, looking forward to your feedback and printing results 😉
Dieses Thema wurde geändert Vor 6 years von Jakub Dolezal
Assembly manuals
/ Knowledge Base
Veröffentlicht : 05/06/2018 4:04 pm
Martin_au
(@martin_au)
Re: Cura settings for the Original Prusa i3 MK3, MK2.5 and MK2/S
Ahahaha. Ironic timing. I just spent the weekend getting Cura playing nicely with the mk3. 😀
Looking forward to having a play with these.
Veröffentlicht : 06/06/2018 1:19 am
lord-carlos
(@lord-carlos)
Infill speed with 170 mm/s seems kind fast?
I had to turn it waaay down in larger prints.
Or is it because I customized some other settings?
Edit: Also I want to thank you for providing cura settings and a really nice manual on how to do it!
Veröffentlicht : 06/06/2018 2:20 pm
Thanks for a great guide, particularly the Mac instructions!
Veröffentlicht : 06/06/2018 5:41 pm
Brandon
(@brandon-3)
I had also just finished building a machine profile for Cura, and got it to work well. With the amount of effort I put into building that, I'm hesitant to switch. Anyone had time to use these new settings?
Veröffentlicht : 06/06/2018 6:09 pm
Cynical Owl
(@cynical-owl)
You want to chuck your settings up here as well? I'm doing some overall tuning with my machine be interested in at least comparing settings in-game and in with some basic test prints.
Veröffentlicht : 06/06/2018 7:02 pm
lord-carlos
(@lord-carlos)
Your current settings don't get lost.
It takes 10 minutes to set up, plus an print test.
I turned down the speed, switched zhop on and some infill changes.
Veröffentlicht : 07/06/2018 10:56 am
ulf.o
(@ulf-o)
Thanks! Nice to see official settings. What other materials are being tested for Cura?
My MK3 arrives on monday, and I'm excited like a little kid before christmas 😀
Veröffentlicht : 07/06/2018 2:57 pm
gustavo.s2
(@gustavo-s2)
i had to reduce infill speed also... below 100ms ... and changed the 5% infill to 20%... reduced outside perimeter infill a little too... than everything went well... was using a wierd gold stringing petg i have... had problems with it before... but it works... 🙂
Veröffentlicht : 08/06/2018 3:02 am
fly3rman
(@fly3rman)
Thanks! As far as i see the M900 is nowhere here. Any way to provide it specific per filament type instead of start g code for the printer in Cura?
Veröffentlicht : 08/06/2018 7:30 am
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
New version 1.2 released! Please download the package for your printer, delete all the old "layer height" profiles and import new ones. Links are in the first post.
Assembly manuals
/ Knowledge Base
Veröffentlicht : 10/06/2018 11:34 am
Cynical Owl
(@cynical-owl)
Can you give a quick summary of what was updated/changed? Good to know what we might want to address in custom (or modified Prusa) profiles, also how Prusa Research sees Cura interacting with the MK3.
Veröffentlicht : 10/06/2018 7:50 pm
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Hi CynicalOwl,
we've changed retraction, amount of infill and disabled supports by default. Mostly small tweaks to improve the print quality. Changelog is in the first post and in the downloaded package.
Can you please be more specific on "how Prusa Research sees Cura interacting with the MK3." ?
Thanks 😉
Assembly manuals
/ Knowledge Base
Veröffentlicht : 11/06/2018 3:00 pm
Cynical Owl
(@cynical-owl)
Hi CynicalOwl,
Thanks 😉
Oh changelog, should have opened the package. Perfect 🙂
I'm just interested what Prusa is working on or identifying as printer-specific settings - hardware/firmware interaction vs day to day quality/performance settings. Helps to further understand the myriad of control points in any slicer. Also I'm testing switching from Slic3R and curious what settings aren't a 1:1 transfer.
Thanks
-owl
Veröffentlicht : 11/06/2018 4:52 pm
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
I can't dig into details, since this is a field of expertise of my colleagues, however, for Cura we took the previously used custom profiles, printed test objects on MK2.5/MK3 and evaluated them. Josef and our printing gurus are experienced enough to recognise the source of the defect on a printed object, so they tweak the profile and print it again. This repeats until we find settings, we are satisfied with.
Modern slicers are pretty complex and each developer has his unique way of thinking, so from what I've seen the software differs in its logic, which can result in different print quality under the same settings. Even our fork of Slic3r differs in some parts from the original Slic3r in terms of internal logic.
Another great influencer are materials since there are no rules for the quality, every producer makes his product slightly differently. Also, their quality can differ in time (batches), so two spools of the same material from one manufacturer can be different. Therefore you set some parameters, which work for the majority.
All these things, plus many others (type of pulleys, temps, linear advance, print speeds, ...) has to be taken into account. My colleagues are spending hours and hours printing and tweaking. It is very time consuming, but the results are worth it 😉
Assembly manuals
/ Knowledge Base
Veröffentlicht : 11/06/2018 9:52 pm
Ben
 Ben
(@ben-4)
The results are, your printer is flipping awesome! I have worked with Stratasys Fortus, Stratasys Dimension Elite, Makerbot, Formlabs, Objet, and I say that your humble 'bloody smart' printer is definitely better than 'professional' grade FDM style printers, and I think it is even preferable to the other types I mentioned. You are doing a great job with this product and I cant wait to see what you have up your sleeves next! In particular I look forward to the MMU.
Keep up the great work! You all clearly know what you are doing!
Veröffentlicht : 12/06/2018 2:55 am
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Hi Richard,
thank you! The entire team is doing their best to stay the nr.1 FDM printer in the World 😉
Assembly manuals
/ Knowledge Base
Veröffentlicht : 12/06/2018 8:32 am
ram64
(@ram64)
Thank you. Tried my own settings but there was always something off. You have to appreciate the effort put by the guys Prusa Research into supporting other slicers.
Veröffentlicht : 12/06/2018 9:06 am
tabicat
(@tabicat)
Can you add a link to the GitHub pull request when you have it?
Veröffentlicht : 13/06/2018 1:00 am
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Hi Ram64,
try to compare yours and ours to see, where it differs 😉
Assembly manuals
/ Knowledge Base
Veröffentlicht : 13/06/2018 8:28 am
Seite 1 / 5
