[Solved] Challenge to the community filament diameter variation
Tinkerwest
(@tinkerwest)
Challenge to the community. I have a design that is very sensitive to filament diameter, 1.75 is tight and 1.71 is loose. Tight is good. I would like to compensate for the variation by increasing the Extrusion Multiplier. The area difference is about 4.5%. Should I increase the multiplier by 4.5% this seams like a lot?
I realizes this may require trial and error but I’m hoping that you all can save me some time.
Thanks in advance. 😀
Best Answer by bobstro:
You should enter the average filament diameter into the Filament settings profile. The slicer will do the compensation you're describing.
Posted : 27/08/2019 2:55 am
timo.m
(@timo-m)
RE: Challenge to the community filament diameter variation
So what exactly is the challenge/question here? If you are having issues with smaller filament (if that is consistent of course) , adjust as you need.
Your calculation is sound.
Posted : 27/08/2019 9:06 am
Posted : 27/08/2019 12:55 pm
Tinkerwest
(@tinkerwest)
Posted by: bobstro
Thank you for your help, I admit I forgot about that setting. Also thanks for sharing your note book, good info.
PS -for any interested it looks like my simple math did work. I printed it last night (before seeing bobstro post)using the tune set while print. The only advantage of this approach is you don’t need separate gcode for each color. I have lots of colors from multiple vendors so I might keep this approach around.
Posted : 28/08/2019 2:47 am
