Can't find STL-file for Extruder cover B6/R2 Mk3
AlexBware
(@alexbware)
Extruder coverHi there. A friend of mine had his Mk3 break down some time ago. He ordered replacement parts, and noted that his extruder cover was slightly melted. He asked me to print a new one. I did from the files at the Prusa page - But what do you know, it did not fit.
It appears that the files on the prusa-page are a newer version.
I have looked many places, but my google-fu is not strong enough.
Can anyone direct me towards the STL-file for the B6/R2 MK3 extruder cover (as on the picture).
Cheers
/Alexander
Postato : 15/02/2020 8:08 am
RH_Dreambox
(@rh_dreambox)
RE: Can't find STL-file for Extruder cover B6/R2 Mk3
Have you tried here?
https://www.prusa3d.com/prusa-i3-printable-parts/#_ga=2.97479391.1108886777.1581766256-891187817.1581075156
Postato : 16/02/2020 9:55 am
rmm200
(@rmm200)
Thanks for that. Bookmarked.
Postato : 16/02/2020 5:13 pm
Ger
 Ger
(@ger)
Hi to all,
same Problem here, but the link posted above does only link to the root page of STL parts, and I can not find the part in the MK3 list.
Thanks for your help.
gerard
Postato : 31/01/2021 12:05 am
RH_Dreambox
(@rh_dreambox)
I tried to download MK3 STL right now and it was no problem.
The package contains 38 STL files, is there any file missing there?
Postato : 31/01/2021 7:54 am
Ger
 Ger
(@ger)
Yes it is possible to download the mk3 zip archive, but it’s version B7/R3 for the extruder cover and I need B6/R2 version. I’m just in a big printing job, and the cover melted, for a fast repair I would just replace the cover with the original form. Later I surely will update the MK3 with the new parts B7/R3 or even upgrade to MK3S+.
Postato : 31/01/2021 2:09 pm
Posted by: @ger
I poked around on the Prusa GitHub pages and can't seem to find older releases. Fortunately, I downloaded a set back in 2018. Most of the parts are labeled R2, but the fan shroud itself is not. This is the vertical style shroud.
Attachment removed
Attachment removed
Postato : 01/02/2021 3:58 pm
Ugh. Hate the quick edit timeout. Here's the R2 extruder cover.
Attachment removed
Postato : 01/02/2021 4:05 pm
1 persone hanno apprezzato
Ger
 Ger
(@ger)
Thanks very much
Postato : 04/02/2021 12:18 am
