Brim Gaps, what?
muo
 muo
(@muo)
Brim Gaps, what?
is this normal or an issue i dont seem to have noticed until now,  should i even be concerned about this, parts seem to print fine so is this an issue at all.
part of the Brim has gaps but not all of the sides of the brim has gaps
as you can see the following has gaps but not in the entire brim. the brim on the right at its top right side does not have gaps and the brim on the left does not have gaps on its top left side, why is this happening, only part of the brim has gaps but not the entire thing?
right side has no gaps only left
only the left has gaps not the right side , right side seems even
the printed parts seem to be fine at least from what i can visually see
parts seems to be fine both which were printed with the brims above also the scar that is on the part that still has the brim is where i had paused the print.
what could be causing this Z is to high or clog maby, mes-bed not leveled correctly, oil or unclean bed perhaps, retraction, etc...?
This topic was modified 7 years ago by muo
Posted : 18/09/2019 9:54 pm
RE: Brim Gaps, what?
Brim strands are normally welded together fairly well, but some gaps are expected.  The back-lit brim looks a little bit odd, but brim on the silver part looks okay.
If I were concerned a cold pull then extrusion multiplier would be my first checks.
Posted : 19/09/2019 10:43 pm
