auto load quit working Mk3
auto load quit working, unload works, prints fine. what do I check.
Thanks Gary
Opublikowany : 30/12/2019 4:00 pm
RE: auto load quit working Mk3
You have 2 choices
1. Turn off auto load
2 upgrade to mk3s
Opublikowany : 30/12/2019 4:32 pm
Autoload is tied in with the filament sensor. The sensor must be enabled and functioning properly for autoload to work reliably. Make sure the sensor is clear of any debris. If you've got a Mk3s, the procedure is a little different than for the Mk3. For the Mk3, a blast of air may suffice. If it's really fouled, you may have to remove the extruder top cover and carefully clean the sensor. Avoid touching the sensor face. Mine seems to need a good blast about every 3-6 months.
Opublikowany : 30/12/2019 9:57 pm
