RE: any suggestions on what went wrong? 95% success
Its really really handy to get into the habit/workflow of saving a project in PS and then hitting slice for the gcode. As its a container with not only the models and the print, filament and printer settings used, it also has their positions, any modifiers or per object settings, any variable layer heights, any custom gcode etc. Its a self contained snapshot.
As well as their usefulness in debugging issues 🙂 they can also be used to get back to the settings easily as you can use the File>Import>Config from project option to load in a 3mf projects settings without opening it. So you can work on something and go 'oh I want to use the settings I used for xyz on this model' and just load them in.
@tim-2
You lost me…. *Rapidly deletes model and drag and dropping a new one in prussslicer without saving.
@neophyl
Will do!
@puanow
Perhaps Neo can help; clearly my attempts are failing.
I printed the fils successfully with the standard Prusa parameters.
@tim-2
Haha, I was alluding to I never saved it in the past, so I dont have a record of what might have gone wrong.
I can still save one now, but I dont think a new file would be helpful, since its working now.
you all were probably right with nozzle temp!
