Any good cover to cover the i3 mk3s?
prusanewuser
(@prusanewuser)
Hi, anybody found a good cover to cover up the i3 mk3s with the T-shaped spool holder?
Opublikowany : 12/08/2019 7:32 pm
Dave Avery
(@dave-avery)
RE: Any good cover to cover the i3 mk3s?
extended leg lack enclosure works for me...
https://www.thingiverse.com/thing:3296106
is what i used
Opublikowany : 12/08/2019 7:49 pm
No recommendations, but filament shouldn't be left "stored" outside a dry container (ziplok bag with desiccant or similar) so removing the spool holder should not be a concern.  But you might mean ENCLOSURE rather than a dust type cover.
This post was modified 7 years temu by --
Opublikowany : 12/08/2019 7:51 pm
prusanewuser
(@prusanewuser)
Yes, for the time being, I store the filament in the ziplok bag that came with the filament. Will work on storage later.
I mean dust type cover. I don't want to remove the T-shaped spool holder from the printer because it was difficult to put it on and it looks like if I do something about it again, it will break.
Opublikowany : 12/08/2019 8:42 pm
The nylon does come off does come off ... and you might consider this (or many other user options out there):
https://www.thingiverse.com/thing:3334728
https://www.thingiverse.com/search?q=spool+holder+mk3
Opublikowany : 12/08/2019 9:07 pm
1 ludzie polubili
prusanewuser
(@prusanewuser)
Thanks.
Opublikowany : 12/08/2019 10:44 pm
Sembazuru
(@sembazuru)
Are you looking for a dust cover to put on the printer when not using it (like grill cover), or an enclosure that the printer sits inside while you print with it?
See my (limited) designs on:
Opublikowany : 13/08/2019 12:10 am
prusanewuser
(@prusanewuser)
Posted by: Sembazuru
When not using it.
Opublikowany : 13/08/2019 12:13 am
Sembazuru
(@sembazuru)
Posted by: peter.c20
When not using it.
I was going to first mention using a trash bag, but on second thought that might be bad for static. A cotton pillow case might work in a pinch (but also might not be large enough around...). Find someone with a sewing machine and provide them with the cotton (for non static) fabric?
Opublikowany : 13/08/2019 12:21 am
RyanG
(@ryang)
This link takes you to a great idea...
https://www.thingiverse.com/thing:3501832
For transparency, I didn’t actually print the support structure, although I’m sure it would work fine. I did, however, purchase the plastic/nylon cover spelled out on the page. Got it from Amazon. I just slip it over the whole printer when I’m done. Fits perfectly, is anti-static, and worked fine when I had the stock spool bracket on the crossmember, and now works just fine with my MMU2S setup on the crossmember.
My printer lives in my garage/shop and the cover does a phenomenal job of keeping it clean. 10/10 will continue to use!
This post was modified 7 years temu by RyanG
Opublikowany : 13/08/2019 1:39 am
2 ludzie polubili
A cheap grill cover from Walmart ...
Opublikowany : 13/08/2019 7:30 am
bob
 bob
(@bob)
I use this https://www.amazon.com/gp/product/B01EW4EWP8/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Opublikowany : 20/08/2019 11:15 pm
