3.13.2 Firmware for MK3, MK3S, MK3S+
Page 2 / 2
NicholeKnc
(@nicholeknc)
RE: 3.13.2 Firmware for MK3, MK3S, MK3S+
Yes, I have been checking GitHub.
Funny thing is right after I posted this I discovered a way to trick the system into allowing me to get around the filment check. Itismore to the bug then yes or no answer.
When the filament sensor is o an its setting set to all yes, filment loaded. The filament check would spin up the extruder, hot or cold. I kept it turned off.
I heated up, unloaded the filament. Turn the sensor off then back on and set all its settings off.
Next to he and selected the sheet I wanted to calibrate. Got told to load the filment and the screen went back. It took a couple of times but I got sent back to the main screen with the selected uncalibrated sheet still selected. I loaded the filament and was able to do a first layer calibration on the selected sheet.
I repeated this process three times, three different uncalibrated sheet slots. So I know this is a work around for this bug.
Publié : 03/03/2024 11:35 pm
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
FYI https://github.com/prusa3d/Prusa-Firmware/releases FW3.13.3
Sorry not a all issue you have reported are solved in this release, but we need to test and release this quite fast. Bigger changes and releases take way longer to be tested  and approved.
Publié : 05/03/2024 2:31 pm
2 personnes ont aimé
burtronix
(@burtronix)
I see FW 3.13.3 has been released. Looking forward to installing it soon.
https://help.prusa3d.com/downloads
Whatever you find to do with your hands, do with all your might!
Publié : 06/03/2024 2:48 pm
Page 2 / 2
