Y Axis Pattern Layer Shifting
lange35
(@lange35)
All of my parts are coming out with layer shifts in the y-direction, but rather than a constant shift that I've seen on forums that would indicate that the printer axes aren't square, mine are coming out with an almost sinusoidal pattern where each layer shifts in a different direction. Does anyone know what could cause this?
Veröffentlicht : 11/09/2021 10:25 pm
Mitglied
RE: Starting
Check your grub screw on the y axis gear.  One of them must be tight against the flat side of the shaft.
Veröffentlicht : 13/09/2021 9:52 am
