[Gelöst] Y axis issues
DavidR
(@davidr-2)
Y axis issues
I've tightened, loosened, and rebuilt the y axis repeatedly. I've gotten all the other axis to configure and setup consistently and correctly.  However, i've gotten y axis to consistently configure, but it won't setup properly, being about 1/2 way off the mark.
Image link: https://photos.app.goo.gl/XTATZQ4NNkvWpoSw8
Veröffentlicht : 08/05/2020 11:48 pm
DavidR
(@davidr-2)
RE: Y axis issues
A bit more clarification.
I purchased a MK3S kit.
Current Firmware version: 3.8.1-2869, have not updated.
After several rounds of troubleshooting, I've gotten the self-test to perform consistently. The X & Z axis line up properly. The Y Axis, however, appears to be about 1/2 cm off the mark, per the photo I've linked. As a result of this, the follow-up XYZ calibration fails, being unable to find the mark.
Things I've tried
Tightening the Y-Belt
Loosening the Y- Belt
Flipped the Frame holding the platform
Re-seated the drive wheel on the Y-motor.
Worked through several other troubleshooting threads.
Veröffentlicht : 11/05/2020 3:13 am
DavidR
(@davidr-2)
RE: Y axis issues
and I lowered the probe 1/4 of a turn and it completed calibration. looks like the Y axis was not the issu
Veröffentlicht : 11/05/2020 3:31 am
RE: Y axis issues
Hi David,
Does your Y axis move back and forward smoothly, by hand?
if not you may have over tightened your Y axis Ubolts
Did you lube the linear bearings when you built the printer?
YES I know what the assembly guide says...
If not, now might be a good time...
https://help.prusa3d.com/en/article/i3-printers-regular-maintenance_2072#rods-and-bearings
Is your Y axis Belt adjuster the correct way round?
Could you be having issues due to friction?
Is your Y motor toothed pulley touching the motor or mounting bracket
Veröffentlicht : 11/05/2020 10:14 pm
