Xyz calibration fail
Hi everybody!
I need your help.
PRINTER PRUSA I3 MK3S
I dont know if somebody already had this problem but when I start my XYZ calibration, first he does the Z, that goes fine, then he asks to put paper under nozzle.
Then on the last position (left far corrner) he said that calibration failed.
The PINDA sensor is 1mm higher so I dont think that is a problem, and the thing that I don't understand is that nozzle never touches the surface.
Pls is someone already had this problem your help would be more then helpful!
Thank yo
u all in advance!
This topic was modified 6 years temu by antonio.j
Opublikowany : 06/08/2019 10:24 pm
RE: Xyz calibration fail
There have been at least 12 threads (hundreds of posts) this week, you should search for them and see if any solutions were provided.
Opublikowany : 06/08/2019 10:25 pm
