XYZ calibration, Bed calibration point was not found
Kurosakidom
(@kurosakidom)
Hello,
I've just completed the mounting of Prusa I3 kit.
But for the XYZ calibration, I've this message "XYZ calibration failed. Bed calibration point was not found."
When I made an Auto home, at the end of the procedure, the extruder head shifts (X+12mm, Y+6mm) and the PINDA isn't center over the 1st calibration point (not like the photo of the point 5 above). But it 's OK if I moved the head at X=0 and Y=0.
When I made the XYZ calibration, the PINDA doesn't move above the 1st calibration point and the test failed 🙁
Do you have an idea of problem origin and to resolve this problem ?
Thanks for your help.
Dominique
Respondido : 01/09/2018 10:07 am
Kurosakidom
(@kurosakidom)
Re: XYZ calibration, Bed calibration point was not found
the photo it's in this web page about XYZ calibration error
https://help.prusa3d.com/l/en/article/fja7hbb22y-xyz-calibration-error-messages-mk-3
Respondido : 01/09/2018 10:29 am
AnderOak
(@anderoak)
RE: XYZ calibration, Bed calibration point was not found
Hey Dominique, I have the same problem here.
PINDA not stop in the center of the 1st calibration point when i use Calibration Auto-home.
And I don't know how to solve it. 🙁
Esta publicación ha sido modificada el hace 7 years por AnderOak
Respondido : 23/08/2019 7:07 pm
Usually PINDA height or a sticky axis.  If you didn't grease the bearings before you installed them, try adding a few drops of oil to the rods and work the axis back and forth to get the oil into the bearings.  Make sure the PINDA is between 0.8 and 1.2 mm above the nozzle tip.
Respondido : 23/08/2019 7:20 pm
AnderOak
(@anderoak)
I needed to better align the x axis as it had left the screws loosely tightened.
But after the tips of this posts worked for me.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/pinda-is-out-of-align-and-z-calibration-issue/#post-159789
Respondido : 23/08/2019 9:28 pm
at24_3d
(@at24_3d)
Hi, I have tried all of the above, I've updated the firmware, I've tested the PINDA, I've adjusted the PINDA, full reset.
Every time I try to do the calibration it continues to fail - bad calibration point was not found...
I am at a loss...
Any further suggestions will be gratefully received....
Respondido : 12/09/2020 11:51 am
Redferne
(@redferne)
@at24_3dnow
I'm having the exact same problem. Completely dumbfounded...
Respondido : 26/09/2020 1:06 am
pcweber
(@pcweber)
Miembro
Yesterday I had the same problem, went through numerous checks from this post and the support personnel at PRUSA finally I found the error. If all tests fail to identify the problem then the most ludicrous becomes the solution. I had a spare PINDA probe in my spares box and reluctantly replaced the installed one. IT WORKED! This after following the posts here and following an upgrade of the extruder using the 3S+ plastic, which by the way has corrected the MMU3s feed probñems. The IR lever and feed path has been greatly improved by the Prusa team. Kudos, right off there are no feed problems. Up to now 100% feed with no failures.
I hope that this helps somebody.
Stay safe and healthy, Phil
Respondido : 11/12/2020 8:41 am
3DPrinterGuy=9134
(@3dprinterguy9134)
I need help please.
I tried to run the XYZ Calibration on my new Original Prusa i3 MK3S 3d printer and encountered two technical issues that I hope you could help me resolve. The two technical issues are as follows:
1. When I ran the XYZ Calibration the first time, the error encountered was "Calibration failed! Check the axes and run again."
For this issue, I resolved it by moving the extruder all the way to the top of the z-axis. However, if I start the XYZ Calibration with the extruder at the middle of the z-axis, I encounter this error again. Is this supposed to be the case? or am I supposed to be able to calibrate wherever the initial position of the extruder is?
2.The second technical error when I ran the XYZ Calibration was "XYZ Calibration failed. Bed calibration point was not found."
  For this issue, I tried alignment changes of the y,x, and z-axis to the Prusa printer as well as lubricating the smooth rods on the z-axis and the x-axis but the extruder is not finding the bed calibration point. I tried adjusting the height of the PINDA but I don't think that is the issue. I also tried making sure that the nozzle is barely touching the heatbed by putting a piece of paper on top of the heatbed but the bed calibration point was still not found. Please advise. Thank you.
Looking forward to hearing your response.
Respondido : 03/01/2021 1:55 am
JPLau001
(@jplau001-2)
Please confirm which  Prusa I3 Mk3 printer version you have (i.e. a MK3, a MK3S, or a MK3s+).
If your kit was shipped after October 2020 then it is likely to be a MK3S+ kit with a SuperPINDA provided instead of the original PINDA probe.  As such your printer requires a firmware level of 3.9.2 or higher for a Prusa I3 MK3S/MK3S+ that is available from the downloads webpage ( https://www.prusa3d.com/drivers/ ).
Also check that your X and Y axis GT2-16 pulleys have been correctly tightened down on to the flat parts of the relevant stepper motor D shafts. one grub screw should be screwed down perpendicular to the flat part of the D shaft before the second grub screw is screwed on to the cylindrical part of the shaft.  The screw on the flat part prevents the GT2-16 pulley from slipping on the shaft as the stepper motor rotates it.
See:
  1. step 28 (with final adjustment and tightening in step 35) for the y axis ( https://help.prusa3d.com/en/guide/2-y-axis-assembly_165795#177222)
  2. step 10 for the X axis ( https://help.prusa3d.com/en/guide/3-x-axis-assembly_167854#168312)   with it's final adjustment and tightening in step 51 for the E axis assembly  ( https://help.prusa3d.com/en/guide/5-e-axis-assembly_169235#171666)
During calibration/autohoming your extruder carriage on the x axis should move to the left and bump into the left side twice before moving the Heated bed (on the y axis) backwards and bumping into the rear twice. This is when you're looking at your Mk3/S/S+ from the front side.  If the movement of an axis is reversed then you have the relevant stepper motor plugged into the Einsy board with its connections reversed.  Having reversed X or Y axis motor movement can cause auto calibration issues.
Respondido : 03/01/2021 1:31 pm
3DPrinterGuy=9134
(@3dprinterguy9134)
@jplau001
I originally posted this on a thread called "XYZ first calibration point not found. Frustrating." on 2/15/21.
Hello,
Since November, I wasn't able to use my Original Prusa i3 MK3S printer (w/o the Multi-Material Upgrade) because of the technical issues regarding the XYZ and bed calibration.
1) I did all the suggestions from the forums regarding calibration of XYZ and the HeatBed and nothing works.
2) I lubricated all the bearings with sticky lubricant and the z-rods with regular lubricant.
3) I checked the P.I.N.D.A sensor in multiple positions and it works fine.
4) The self-check was successful.
5) The auto home runs successfully.
6) I checked that the firmware of the Original Prusa i3 MK3S printer that we bought is 3.9.2-3594.
Yet still, the XYZ calibration fails before the detection of the 1st-bed calibration point.
Respondido : 19/02/2021 6:15 pm
chad.k
(@chad-k)
@3dprinterguy9134
I was having some similar problems after installing the MK3S upgrade, and it turned out I made two mistakes:
1: Incorrect zip tie positioning on the wire bundle on the back of the extruder assembly.  Both the top bundle of wire and the bottom had zip ties ends which were hitting the Einsy case, and they must not hit either the Einsy case or the power supply for the printer to correctly find its calibration points.
2: My Y axis belt was too tight (despite the fact the belt check reported that I was well within the correct range) and sticking a bit (polymer bearings needed a little oil to run smoothly). If the belt check comes up with values near the low end of the allowable range (240-300), loosen the belt a little.
Honestly, I had some weird problems running calibration in 3.9.3.  Usually I'd fail on the first calibration point, sometimes I'd get to the third, and the output to pronterface seem to show the calibration point in the bitmap (although quite weakly) when it fails, but a good strong signal when it succeeds.
Respondido : 23/02/2021 3:13 am
1 les gusta
Dejf
 Dejf
(@dejf)
Today I fixed a few things, namely loud Z axis and calibration failed to find point 2 and then point 1... Ok,  what did I do between point 1 and 2 of first run? Yeah, fixed the paper with magnets, so I dont have to baby sit all the time. I took magnets away and calibration went fine. So even slight (magnets are tiny and between the corners) magnetic field change completely kills the calibration proces. Maybe look for lost fixation magnet under the bed 🙂
Esta publicación ha sido modificada el hace 5 years por Dejf
My opinion may not be right, but regret having so bad and right one too often.My models are things you can't see on any shelve. I create things that don't exist and that should be the…
Respondido : 30/05/2021 6:25 pm
Egor Sovtsov
(@egor-sovtsov)
Miembro
In my case it was incorrect zip tie assembly preventing the extruder from going all the way to the left on X axis.
Respondido : 22/02/2024 7:15 am
