X axis Belt touches the left support
josu
 josu
(@josu)
Hello to all
I, ve just mounted the prusa MKS3 Kit.
Everything works fine but I have the problem that the X Axis Belt touch the left support.
I have test the position of the X axis motor and aligment and it seems Ok.
I don't know how to fix IT.
Thanks un advance
Questa discussione è stata modificata 5 years fa da josu
Postato : 30/03/2020 3:25 pm
RE: X axis Belt touches the left support
Your roothed wheel is back to front. The fastenning boss should be at the end of the shaft. Not next to the motor
Postato : 30/03/2020 3:59 pm
josu
 josu
(@josu)
Thanks JoanTabb
Then I have to reverse the roothed wheel?
Postato : 30/03/2020 4:09 pm
Jerry
(@jerry)
Or turn the printer while the pulley remains stationary
Postato : 30/03/2020 6:23 pm
Steve
(@steve-5)
@josu
Yes, the x-axis toothed wheel is installed "backward" with the narrowest part of the wheel closest to the stepper motor.  Be sure that you tighten the set screws in the correct sequence as well, one screw tightened onto the flat of the shaft and only then tighten the second.
Regards,
Steve
Postato : 30/03/2020 8:45 pm
josu
 josu
(@josu)
Thanks to all. I'll fix it 😉
Postato : 30/03/2020 8:46 pm
josu
 josu
(@josu)
Fixed. Thank you.
Postato : 30/03/2020 9:43 pm
Roothed wheel... I hate mobile phone onscreen keypads...
but you got the idea...
Regards Joan
Postato : 30/03/2020 9:46 pm
nilok
(@nilok)
Roothed wheel = Reversed Toothed Wheel
makes sense to me
Is your printer grinding? Bearings squeaking? Motors smoking?
Step 1) Wash your Steel Sheet
Step 2) Return to Step 1
Postato : 30/03/2020 9:56 pm
