					                		Weird sound from printer. - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/</link>
                <lastBuildDate>Thu, 16 Apr 2026 02:41:26 +0000</lastBuildDate>
                        <title>RE: Weird sound from printer.</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-141070</link>
                        <pubDate>Sun, 05 May 2019 05:19:01 +0000</pubDate>
                        <description><![CDATA[So I opened the door checked the alignment....Looks goodput the tension screw back in but did not set it as tight as it was last time.  Before: Just about a full rotation past flushNow: Just...]]></description>
                        <content:encoded><![CDATA[<p>So I opened the door checked the alignment....Looks good</p><p>put the tension screw back in but did not set it as tight as it was last time.  </p><p>Before: Just about a full rotation past flush</p><p>Now: Just about a quarter rotation past flush</p><p> </p><p> </p><p>Thank you guys for the help sound is gone now.  Hopefully, I didn't cause any damage.  I prolly printed about 50 hours or so before the fix.</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Mike</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-141070</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-140712</link>
                        <pubDate>Fri, 03 May 2019 05:45:56 +0000</pubDate>
                        <description><![CDATA[Also - there are instructions on the Bondtech site that say the bearings provided with the gear set are to be lubricated before installation.Bondtech Filament Drive GearsA Lithium based grea...]]></description>
                        <content:encoded><![CDATA[<p>Also - there are instructions on the Bondtech site that say the bearings provided with the gear set are to be lubricated before installation.</p><p><a href="https://www.bondtech.se/en/product/drivegear-kits/" target="true">Bondtech Filament Drive Gears</a></p><blockquote><p><span style="color: #0000ff">A Lithium based grease is recommended to use on the gear section and inside the needle bearings for low friction and to avoid wear. A small dab of grease is enough.</span></p></blockquote>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>--</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-140712</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-140651</link>
                        <pubDate>Thu, 02 May 2019 17:10:36 +0000</pubDate>
                        <description><![CDATA[Make sure the rod in the door is still centered in both ears. It causes squeaking if it is not.]]></description>
                        <content:encoded><![CDATA[<p>Make sure the rod in the door is still centered in both ears. It causes squeaking if it is not.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>vintagepc</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-140651</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-140628</link>
                        <pubDate>Thu, 02 May 2019 15:05:09 +0000</pubDate>
                        <description><![CDATA[If you mean the squeaking sound while retraction, it&#039;s the gear inside the idler. I didn&#039;t have this in the beginning then adapted something and I got this squeaking. Just play around with t...]]></description>
                        <content:encoded><![CDATA[<p>If you mean the squeaking sound while retraction, it's the gear inside the idler. I didn't have this in the beginning then adapted something and I got this squeaking. Just play around with the tightness of the screws. That's what worked for me at least.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>gkPrints</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-140628</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-140541</link>
                        <pubDate>Thu, 02 May 2019 04:09:47 +0000</pubDate>
                        <description><![CDATA[I know no one has had a chance to weigh in yet, due to my post needing approval (i assume because this is my first post) but I believe it is the spring on the screw that holds the idler door...]]></description>
                        <content:encoded><![CDATA[<p>I know no one has had a chance to weigh in yet, due to my post needing approval (i assume because this is my first post) but I believe it is the spring on the screw that holds the idler door shut or the idler itself.  At least that's where I think the sound is coming from.</p><p> </p><p>needless to say, prints right now are looking near perfection, should I tighten it? </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-140541</guid>
                        <title>Weird sound from printer.</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-140520</link>
                        <pubDate>Thu, 02 May 2019 02:22:54 +0000</pubDate>
                        <description><![CDATA[So this is my second printer, first Pursa.  I have printed 3 objects so far and they are amazing.  Needless to say when printing (even on the first few layers) I get this squeak.  Is this no...]]></description>
                        <content:encoded><![CDATA[<p>So this is my second printer, first Pursa.  I have printed 3 objects so far and they are amazing.  Needless to say when printing (even on the first few layers) I get this squeak.  Is this normal?</p><p> </p><p>https://youtu.be/_cXBhAXiRz0</p><p> </p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/weird-sound-from-printer/#post-140520</guid>
