Weird droop/ over extrusion?
So, im getting these weird effects on this print. The drooping only seems to hit the bottom of the print and the top of the print (It gets popped off the build plate) is sort of built up which i assume is over extrusion? Any advice? This is running at 205 temp and with an extrusion multiplier of 0.95. with the included filament. ( https://imgur.com/a/KpaDvNA)
RE: Weird droop/ over extrusion?
Image is not showing. To insert a pic, either:
- Drag & drop the image into the edit box.
- Use the Add Media button above to upload images.
I believe a solution may have been to just add more supports. Not a permanent one but at least one for this print. Will update as it gets further along in the print.
