Top of spires on castle went blobby
Keith Cassidy
(@keith-cassidy)
I printed the included  `Castle_0.1mm_PLA_MK3S_13h55m.gcode` in the silver PLA included with the printer
Just the top of some of the spires and especially the top spire went blobby:
Any ideas? My benchy was perfect.
Opublikowany : 25/09/2020 10:57 am
Steve
(@steve-3)
RE: Top of spires on castle went blobby
It may be that the previous layers do not get a chance to cool when the spires get tiny. Try increasing "Slow down if layer print time is below" under "Filament Settings -> Cooling".
Steve
Opublikowany : 25/09/2020 6:32 pm
Keith Cassidy
(@keith-cassidy)
@steven-p8
Thanks, I printed straight from the included gcode files so i wondered if it was a hardware problem - I would have assumed the included files would print correctly with a correctly setup printer?
Opublikowany : 25/09/2020 7:03 pm
ds21_old
(@ds21_old)
Posted by: @steven-p8
Steve
I have a feeling that this is not the issue since the spires at lower z-levels fail in a similar way when there is more to print on the same layer elsewhere.
I can also see some poor extrusion in other spots where small details are being printed. My first attempt would be to make sure the extruder gears are tightened properly.
Opublikowany : 28/09/2020 6:23 pm
ekmek polubić
