Test print doesn't start properly
I'm in the middle of calibrating the printer, and I think I've managed to get it to the correct height for the final square to print correctly, at -1.70 (-1.60 was too high, and the square would split apart if you bent it, and 1.5 was too low, causing deformities in the square)
The problem I'm seeing is that the print never seems to start in the exact place it should. It doesn't start in the top left properly, and the initial line is flatter than normal until it gets halfway through the top line. Any advice?
Posted : 08/09/2019 12:30 am
RE: Test print doesn't start properly
All normal. Move on to the Benchy ... and remember finger prints will haunt you - handle the bed only by the edges.
Posted : 08/09/2019 2:33 am
