					                		Stripped Screw and Stripped Screw hole on extruder - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/stripped-screw-and-stripped-screw-hole-on-extruder/</link>
                <lastBuildDate>Sun, 14 Jun 2026 01:04:48 +0000</lastBuildDate>
                        <title>RE: Stripped Screw and Stripped Screw hole on extruder</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/stripped-screw-and-stripped-screw-hole-on-extruder/#post-692323</link>
                        <pubDate>Tue, 02 Jan 2024 20:49:14 +0000</pubDate>
                        <description><![CDATA[I have tried all methods so this leaves cutting the visible thread with a Dremel and pulling the rest out.]]></description>
                        <content:encoded><![CDATA[<p>I have tried all methods so this leaves cutting the visible thread with a Dremel and pulling the rest out.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Rocket printer</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/stripped-screw-and-stripped-screw-hole-on-extruder/#post-692323</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/stripped-screw-and-stripped-screw-hole-on-extruder/#post-692150</link>
                        <pubDate>Mon, 01 Jan 2024 20:34:49 +0000</pubDate>
                        <description><![CDATA[Thanks for the suggestions. I already tried options 1 and 2, to no effect, so I will try option 3. I exposed the thread on another part but it is not turning even with pliers. I&#039;m not sure i...]]></description>
                        <content:encoded><![CDATA[<p>Thanks for the suggestions. I already tried options 1 and 2, to no effect, so I will try option 3. I exposed the thread on another part but it is not turning even with pliers. I'm not sure if it's stuck or something.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/stripped-screw-and-stripped-screw-hole-on-extruder/#post-692150</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/stripped-screw-and-stripped-screw-hole-on-extruder/#post-692149</link>
                        <pubDate>Mon, 01 Jan 2024 20:23:16 +0000</pubDate>
                        <description><![CDATA[Option 1) grab it with a pliers and turn while pulling.   2) get a small screwdriver under the head to apply outward force while using the hex key to loosen it further.  3) maybe use somethi...]]></description>
                        <content:encoded><![CDATA[<p>Option 1) grab it with a pliers and turn while pulling.   2) get a small screwdriver under the head to apply outward force while using the hex key to loosen it further.  3) maybe use something like https://www.amazon.com/dp/B07YXXZDT9</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>JimB</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/stripped-screw-and-stripped-screw-hole-on-extruder/#post-692149</guid>
                        <title>Stripped Screw and Stripped Screw hole on extruder</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/stripped-screw-and-stripped-screw-hole-on-extruder/#post-692131</link>
                        <pubDate>Mon, 01 Jan 2024 18:56:15 +0000</pubDate>
                        <description><![CDATA[Hi Everyone, I was repairing my Mk3s+ when I accidentally overtightened a screw on the extruder(M3x40). I have managed to get a hex key in and turn it with the screw, but the screw won&#039;t com...]]></description>
                        <content:encoded><![CDATA[<p>Hi Everyone, I was repairing my Mk3s+ when I accidentally overtightened a screw on the extruder(M3x40). I have managed to get a hex key in and turn it with the screw, but the screw won't come back. It's just spinning in the threads. I have gotten it about 5mm out but not any farther. Any Ideas?</p><p> </p><p>Thanks,</p><p>Rocket printer</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/stripped-screw-and-stripped-screw-hole-on-extruder/#post-692131</guid>
