Spare part print issue?
Odin
 Odin
(@odin-2)
I have printed a extrusion idler to have as a spare part
The holes are not round..
Anybody have any tricks to fix this or do i have to process them in order to get a good fit?
I hace included the gcode for anyone to evaluate.
Cheers.
Best Answer by Diem:
you have to fine-tune the prints efter they are finished
It is a mistake to imagine you are printing perfect finished parts.  Better to think of it like casting; you are making custom blanks which you will finish before use.
Respondido : 10/11/2021 2:53 pm
RE: Spare part print issue?
You can almost certainly improve the circularity by careful tweaking of the slice ... but it's quicker and easier to post-process with a needle file or drill bit.
Respondido : 10/11/2021 6:34 pm
Odin
 Odin
(@odin-2)
I did use a countersink to round up the hole after I posted this and it looks much nicer 👍🏻
I do not want to use a drill to make the hole bigger so the pin for the bondtech gear does not fit.
I guess that even if everything is in order you have to fine-tune the prints efter they are finished
Respondido : 10/11/2021 7:07 pm
BogdanH
(@bogdanh)
Posted by: @odin-2
...I guess that even if everything is in order you have to fine-tune the prints efter they are finished
No. If part is properly ("printer friendly") designed, then there should be no need to do that manually.
Circular holes/pockets that are printed vertically, will never have perfect circular shape. Because of that, designer who takes care, will never use simple circle for vertically printed holes.
I just checked this extruder idler, and sadly, designer didn't bother.. he just used a circle.
[Mini+] [MK3S+BEAR]
Respondido : 10/11/2021 8:14 pm
A question of priorities
Posted by: @odin-2
[...] The holes are not round..
It's really a question of where you want to put your time and effort. If I am designing the part, I'll try to avoid the problem. If I'm just printing off a part as a one-off or I don't have the design files, I take a rat-tail file to those holes and be done with it. I do this frequently with M5 GoPro mounts.
Respondido : 10/11/2021 8:18 pm
Respondido : 10/11/2021 8:50 pm
Odin
 Odin
(@odin-2)
I downloaded the STL from Prusa website and followed the instructions
Is there any other parameters in Prusa slicer that can be altered with to make this print usable for a spare part of is it good to go?
I do not have the original part that came with the printe to compare with as it is already mounted on the extruder
Respondido : 10/11/2021 8:58 pm
You could play with alignment, temperatures and speeds but really its an initial design issue - here we can assume that as a great many have been printed and used sucessfully the design tolerances are sufficient for the intended use.
Respondido : 10/11/2021 9:10 pm
BogdanH
(@bogdanh)
Agree with @diem on that. You can try various settings in slicer and maybe you can get better result.. but is kinda a waste of filament and time in this case. Just take a drill and take your time -it will still be faster than experimenting with slicer.
Anyway, in my previous post, I was only explaining why that happens -just so you wouldn't think there's something wrong with your printer. But then, no printer is perfectly adjusted... 😏 .
[Mini+] [MK3S+BEAR]
Respondido : 10/11/2021 9:22 pm
1 les gusta
