Sequential Printing - I'm using Cura
I'm a newbie with a Prusa Mk3S+ and ran into a problem with the Prusaslicer not liking a particular SLI file - maybe my problem rather than the slicer's, but I down loaded Cura for this particular build on the grounds that is what the author had used. The assembly requires 3 identical items, so being brave I set the Cura baseplate up for a Sequential print.
This is Cura 5.2 which seems to have slightly different interface for the menus from the earlier versions, and I found at once that where I had wanted a one-at-a-time print, it is printing all at the same time, but I cannot find the Cura button to change the print to one-at-a-time. Anybody help?
RE: Sequential Printing - I'm using Cura
Hi Robin - try as I might I am sorry but I cannot identify that image with either Cura or Prusaslicer. Maybe I have a different versions of both from yourself because I really cannot find anything from any menu that matches that. Cura is version 5.2.1 and Prusaslicer is 2.5.0. Rob
It shows the setting you are looking for in Cura 5.2.1.
First you need to enable the settings (or just select all), then you’ll find it in the settings drop down in the „special modes“ section as shown in my screen shot.
Ahhh - getting there !!! Settings/Configure settings visibility - and then pages of settings!! But then I don't get on my screen the "All at Once" even when I play around with Advanced / Expert, etc. But as it is I placed my 6 small pieces close together and they printed fine going layer by layer.
Thanks for the additional guidance - I had trawled through that settings list previously but it is so extensive that I may well have given up before I got to the end.
Rob
