Selftest error!Please check: Endstops Wiring error Z
Omega-TI
(@omega-ti)
I purchased an assembled i3 MK3S+ two months ago and have had no problem with, until a few hours ago.  I keep getting this error message and I cannot seem to find the problem.  Any suggestions?
Best Answer by Robin:
 Most probably PINDA probe or PINDA probe wiring. Check if the LED on the PINDA is lit and goes out if you place a metal object below the PINDA. If it does not, check the PINDA wiring but most probably you will need a new PINDA probe.
Respondido : 13/12/2022 4:29 am
Hello
(@hello)
RE: Selftest error!Please check: Endstops Wiring error Z
This can happen by loose wire connecting to einsy break in wire something stopping motor from moving or to much resistince  or worse thing is the einsy won't recognize the end stop
Does the motor move freely when manually moving printer off
Hope this helps
Respondido : 13/12/2022 8:07 am
Robin
(@robin)
Respondido : 13/12/2022 1:07 pm
1 les gusta
...but first unplug and reinsert all the connections at the Einsy in case something has just shaken loose.
Respondido : 13/12/2022 6:18 pm
Omega-TI
(@omega-ti)
Posted by: @hello
Hope this helps
When I try to print from the SD card...
The red light at the bottom left-hand side stays solid until the hot-end heats up, then it blinks as normal, it then moves the print bed as normal, and moves the print head as normal, but as soon as it moves the Z axis up about 3/4 of an inch it stops with the error message.  When I press the control not for the Z axis calibration it moves all the way to the top, then stops giving me the error again.
Posted by: @robin
Ugh, the reason I paid so much for an assembled MK3S+ is because I didn't want to disassemble or assemble anything.  I just wanted to use it.
Posted by: @diem
Everything "looks" fine, without having to disassemble it.  I believe the warranty on assembled printers is a year, so I may have to send it in for repair, because taking it apart would probably void the warranty.  I read the MK3S+ was one of the most reliable printers on the market, but even so I guess someone is bound to roll snake eyes once in a while.
Respondido : 13/12/2022 11:51 pm
Hello
(@hello)
I would contact prusa support though chat as it may be bad einsy
Respondido : 14/12/2022 2:39 am
1 les gusta
Just replugging the two Z axis motors and the PINDA won't void the warranty.If you're worried about it, contact support: Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
They will talk you through the process.
Respondido : 14/12/2022 2:51 pm
1 les gusta
Omega-TI
(@omega-ti)
Yep, it was the SuperPINDA probe.  I FINALLY got around to replacing it today, so I'm back in business.
Respondido : 26/01/2023 4:26 am
1 les gusta
