Self test fan error
crushfx
(@crushfx)
Self test fan error
Hello,
The self test fails due to fan error:
The first fan test passes, but when the second test is performed it asks me whether the fan is spinning or not, to which I say yes (I am able to see it spinning - this is the fan that looks like a snail and connected to the shroud) then it says fan error. If I say no (the fan is not spinning) to it first, then say yes it ends successfully but if I say no right from the get-go it gives me a fan's swapped' message. I checked my wiring is correct twice. If I reverse wiring on the motherboard, the same thing happens but the error happens with the other fan.
To fool it, I first say no (it is not spinning) followed by "yes" to confirm that it is spinning.
What could be wrong?
Thanks!
Posted : 29/04/2019 5:24 am
crushfx
(@crushfx)
RE: Self test fan error
This is what appears on the front panel during self-test:
Extruder fan [ok] - the noctua fan to the left of the extruder starts spinning
Print fan ("snail fan" starts spinning very fast) then about 10 seconds later it asks 'left hotend fan spinning?
I say 'spinning', then get a 'selftest error! please check: front/left fans swapped'
Thanks!
Posted : 29/04/2019 5:48 am
Easy to test: swap the fan plugs in the EINSY case and re-run the self test.
Posted : 29/04/2019 5:59 am
crushfx
(@crushfx)
Swapping cables gets me the same message only for the reversed cables. I looked it up on the forums here and stumbled on some older threads indicating a firmware bug. (all good I guess, fans are spinning after all)
Posted : 29/04/2019 6:01 am
What version FW are you using?
Posted : 29/04/2019 6:15 am
crushfx
(@crushfx)
Posted by: tim.m30
The one dated in April 2019 (april fools?)
Posted : 29/04/2019 3:40 pm
Vojtěch
(@vojtech)
If I recall correctly, it asks twice, but each time about a different fan. That's why the answer needs to be different. The printer is checking whether it's spinning the right fan - it can't check that based on RPM readout alone, it needs the user to see it with their eyes. Are you sure you're reading the questions on the LCD correctly?
Posted : 29/04/2019 4:02 pm
vintagepc
(@vintagepc)
Posted by: Vojtěch
What he said.
Per your message:
You answered "spinning" when you should have said no. The snail fan is not the "left hotend fan".
Posted : 29/04/2019 4:27 pm
crushfx
(@crushfx)
Posted by: vintagepc
Posted by: Vojtěch
What he said.
Per your message:
Ah, I see. That is an interesting approach to detect fan movement, looks like I was indeed interpreting prompts incorrectly as vojtech suggested.
Thanks!
Posted : 29/04/2019 9:39 pm
