SD-card not working
AmandaJ
(@amandaj)
SD-card not working
Hi! I just got my Prusa I3 MK3S+ and Im trying to do my first print but the SD-card outlet does not work.
When I plug the SD card in the screen reacts but only two options show, the "back" and a picture of a SD card, when i choose the SD-card and press "enter" the same meny shows up, and it continues in that way to no end. I can't see any of the models that comes with the SD card and in the meny it says "No SD card".
However when I remove the SD-card it says "SD-card removed" on the overview page.
I have tried changing to another SD-card but it doesn't work either.
Best regards Amanda
Posted : 01/11/2022 10:23 am
Clean the SD contacts and try again just in case - but it sounds like a damaged connector.
As it's new go to Prusa Support: Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Posted : 01/11/2022 3:27 pm
towlerg
(@towlerg)
RE: SD-card not working
SD card are notoriously unreliable, try a known brand, the quicker the better.
Posted : 03/11/2022 4:37 pm
