Recalibration from scratch after replacing PTFE tube and Nozzle
FIX6
 FIX6
(@fix6)
I recently replaced the nozzle and PTFE tube on my MK3S+ and have been having troubles printing ever since reassembly. I have run the wizard and calibrated the first layer but I'm still getting prints globbing and sticking to the nozzle. Imgur of last prints perimeter and brim.
Thanks in advance for any help!
Best Answer by Bob:
The z-offset value is mostly immaterial, a good z-offset for you is likely to be very different from what someone else is getting, so don't get hung up on what the number is, -1.200 may be great for you but too high for me or too low for someone else.  It's a reference point nothing more.  As long as your Pinda probe is about 1mm higher than your nozzle then everything is good and whatever your number is when you get a good squish is what is is.
Typically, though not always, if your nozzle is hitting your print and knocking it off the bed then what is most likely happening is the print is lifting off the bed and it's the print that is getting into the nozzles path rather than the nozzle is in the prints path.
In your first layer print, the rectangle has different shades, it's darker on the sides than in the middle, this is due to the print not sticking well.  Your bed probably isn't clean enough.  The z-offset is probably ok, maybe a touch low, but mostly ok so you need to get your bed cleaner.
Cheers
-Bob
Postato : 13/01/2022 9:49 am
Bob
 Bob
(@bob-2)
RE: Recalibration from scratch after replacing PTFE tube and Nozzle
Do a first layer calibration and send us the photo of that.
Cheers
-Bob
Postato : 17/01/2022 6:35 pm
1 persone hanno apprezzato
FIX6
 FIX6
(@fix6)
Thank you for your response, here is a first layer calibration test photo thanks!
Postato : 02/02/2022 3:57 pm
FIX6
 FIX6
(@fix6)
Sorry it didn't attach the image. here is a link to Imgur.
Postato : 02/02/2022 4:00 pm
FIX6
 FIX6
(@fix6)
Also just to note its currently at -1.200 z distance and it sounds like it's rubbing on prints sometimes, prints are failing by being knocked off their rafts so I just assumed the nozzle was too close?
Postato : 02/02/2022 4:06 pm
Bob
 Bob
(@bob-2)
Cheers
-Bob
Postato : 02/02/2022 4:25 pm
FIX6
 FIX6
(@fix6)
Thanks for your help Bob I'll give her an iso bath.
Postato : 03/02/2022 5:25 am
Robin
(@robin)
Posted by: @fix6
At least 2 posts claiming iso won't be enough in three, two, one...
Postato : 03/02/2022 4:09 pm
DMayfield
(@dmayfield)
Utenti
Posted by: @robin
Posted by: @fix6
Ahh, the western front, I finally made it.  Took me a while to get here. 😀
Postato : 10/12/2024 10:55 pm
