Prusa Noise
Hello!
So I just finished building the mk3s+ kit and it seems to be printing just fine, but it's a lot louder than I was expecting. My last printer (the Artillery Sidewinder X1) was virtually silent and the Prusa sounds a lot more like what I was used to from a 3D Printer of the past.
I'm wondering if there's perhaps something I did wrong in assembly or if that is just what the printer sounds like during operation.
I've attached a video. It doesn't sound like anything is wrong necessarily, but it's just not what I expected.
I appreciate any help you guys can give me.
RE: Prusa Noise
Did you lube the bearings?
Joan
RE: Prusa Noise
@joantabb
I did not. It told me a couple times in the build guide not to and the bearings seemed well lubed out of the bag.
RE: Prusa Noise
@forrest
I would still check if the linear ball bearings are sufficiently greased. Some batches (Misumi) are only provided with an anti-corrosion agent, which is not suitable for continuous operation.If in doubt, I would contact the Prusachat and clarify this (warranty claims).
RE: Prusa Noise
Ok, I'll reach out.
RE: Prusa Noise
Problem could be , on what is your printer standing,
a table could make the noise get worse.
